EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipes according EN 1452 Plastics piping systems for water supply. Unplasticized poly (vinyl chloride) (PVC-U). Fitness for purpose of the system:
For full table with Table Z - rotate the screen!3
Nominal Outside Diameter
(mm)
Min. Wall Thickness (mm)
S 20
SDR 41
S 16.7
SDR 34.4
S 16
SDR 33
S 12.5
SDR 26
S 10
SDR 21
S 8
SDR 17
S 6.3
SDR 13.6
S 5
SDR 11
Nominal Pressure PN (design coefficient 2.5)
PN 6 PN 6 PN 8 PN 10 PN 12.5 PN 16 PN 20
12 1.5
16 1.5
20 1.5 1.9
25 1.5 1.9 2.3
32 1.5 1.6 1.9 2.4 2.9
40 1.5 1.6 1.9 2.4 3.0 3.7
50 1.6 2.0 2.4 3.0 3.7 4.6
63 2.0 2.5 3.0 3.8 4.7 5.8
75 2.3 2.9 3.6 4.5 5.6 6.8
90 2.8 3.5 4.3 5.4 6.7 8.2
Nominal Pressure PN (design coefficient 2.0)
PN 6.3 PN 7.5 PN 8 PN 10 PN 12.5 PN 16 PN 20 PN 25
63 2.0 2.0 2.4 3.0 3.8
75 2.0 2.2 2.9 3.6 4.5
90 2.0 2.7 3.5 4.3 5.4
PN 6 PN 7.5 Pn 8 PN 10 PN 12.5 PN 16 PN 20 PN 25
110 2.7 3.2 3.4 4.2 5.3 6.6 8.1 10.0
125 3.1 3.7 3.9 4.8 6.0 7.4 9.2 11.4
140 3.5 4.1 4.3 5.4 6.7 8.3 10.3 12.7
160 4.0 4.7 4.9 6.2 7.7 9.5 11.8 14.6
180 4.4 5.3 5.5 6.9 8.6 10.7 13.3 16.4
200 4.9 5.9 6.2 7.7 9.6 11.9 14.7 18.2
225 5.5 6.6 6.9 8.6 10.8 13.4 16.6
250 6.2 7.3 7.7 9.6 11.9 14.8 18.4
280 6.9 8.2 8.6 10.7 13.4 16.6 20.6
315 7.7 9.2 9.7 12.1 15.0 18.7 23.2
355 8.7 10.4 10.9 13.6 16.9 21.1 26.1
400 9.8 11.7 12.3 45.3 19.1 23.7 29.4
450 11.0 13.2 13.8 17.2 21.5 26.7 33.1
500 12.3 14.6 15.3 19.1 23.9 29.7 36.8
560 13.7 16.4 17.2 21.4 26.7
630 15.4 18.4 19.3 24.1 30.0
710 17.4 20.7 21.8 27.2
800 19.6 23.3 24.5 30.6
900 22.0 26.3 27.6
1000 24.5 29.2 30.6
Dimensions
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
