EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes according EN 1453Plastics piping systems with structured-wall pipes for soil and waste discharge (low and high temperature) inside buildings. Unplasticized poly (vinyl chloride) (PVC-U). Specifications for pipes and the system:
Nominal Size
(mm)
Nominal Outside Diameter
(mm)
Wall Thickness
(mm)
32 32 3.2
40 40 3.2
50 50 3.2
63 63 3.2
75 75 3.2
100 100 3.2
125 125 3.2
140 140 3.6
160 160 4.0
200 200 4.9
Dimensions
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
Dimensions of PVC pipes according EN 1401.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
