Dimensions of EN 1329 Plastics piping systems for soil and waste discharge (low and high temperature) within the building structure. Unplasticized poly(vinyl chloride) (PVC-U):
Metric Series
EN 1329 - PVC Piping for Soil and Waste Discharge - Dimensions Metric Series
Nominal Size
(mm)
Nominal Outside Diameter
(mm)
Mean Outside Diameter (mm)
minmax
32 32 32.0 32.2
40 40 40.0 40.2
50 50 50.0 50.2
63 63 63.0 63.2
75 75 75.0 75.3
80 80 80.0 80.3
82 82 82.0 82.3
90 90 90.0 90.3
100 100 1000.0 100.3
110 110 110.0 110.3
125 125 125.0 125.3
140 140 140.0 140.4
160 160 160.0 160.4
180 180 180.0 180.4
200 200 200.0 200.5
250 250 250.0 250.5
315 315 315.0 315.6
Inch based Series
EN 1329 - PVC Piping for Soil and Waste Discharge - Dimensions Imperial Series
Nominal Size
(mm)
(mm)
minmax
36 36 36.2
36.5
43 43 42.8 43.1
56 56 55.8 56.1
Dimensions
ASTM D2661 - Acrylonitrile-Butadiene-Styrene (ABS) Schedule 40 Plastic Drain, Waste, and Vent Pipe and Fittings
Nominal pipe size, outside diameter, thickness and weight.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
Dimensions of PVC pipes according EN 1401.
EN 1451 - Polypropylene (PP) Plastics Piping Systems for Soil and Waste Discharge - Dimensions
Plastic piping systems for soil and waste discharge (low and high temperature) within the building structure.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
PVC - Polyvinyl Chloride Pipes - Supports
Distance between PVC pipe supports.
Thermoplastic Pipes - Strength Derating vs. Temperature
Increased temperatures derates the strength of thermoplastic piping materials.
Underground Pipes - Earth Pressure
Pressure acting on underground pipes due to weight of soil and transport.
