Thermal expansion of pipes in PVC, CPVC, Fiberglass and Carbon or Stainless Steel in inches per 100 feet can be found in the diagrams and table below:
Thermal Expansion (inches/100 feet) | |||||
Temperature Change (oF) | Fiberglass | PVC1) | CPVC1) | Carbon Steel | Stainless Steel |
25 | 0.31 | 0.90 | 1.14 | 0.18 | 0.27 |
50 | 0.61 | 1.80 | 2.28 | 0.36 | 0.54 |
75 | 0.92 | 2.70 | 3.42 | 0.54 | 0.82 |
100 | 1.23 | 3.60 | 4.56 | 0.72 | 1.09 |
150 | 1.84 | 5.40 | 6.84 | 1.08 | 1.63 |
For temperature change: 1 oF = 5/9 oC
1) Note the relative huge thermal expansion of thermoplastic plastic materials - like PVC and CPVC - compared to steel.
• Temperature Expansion
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Dimensions of PVC pipes according EN 1401.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Fiberglass Pipes - common Standards
Commonly used standards for fiberglass pipes and their applications.
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
Linear Thermal Expansion: Formula, Coefficients & Calculator
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion - Superficial i.e. Area
Superficial i.e area temperature expansion - online calculator.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
