For sizes 1 1/4" and larger ASTM D2665 for DWV pipe is comparable to ASTM D1785 Schedule 40.
PVC drain, waste, and vent pipe dimensions.
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Dimensions of pressure rated PP pipes according ASTM F2389.
Distance between PVC pipe supports.
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
