For sizes 1 1/4" and larger ASTM D2665 for DWV pipe is comparable to ASTM D1785 Schedule 40.
Dimensions of PVC pipe SDR series.
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Distance between PVC pipe supports.
