Typical weight and dimensions of industrial PVC and CPVC pipes equal to steel pipes schedule 40 and 80 are indicated in the table below.
- ASTM D1785 Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe, Schedules 40, 80, and 120 is manufactured to meet the needs of a broad range of industrial, commercial and residential piping systems. ASTM D1785 covers pipes made for water distribution and irrigation systems.
- ASTM F441 Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Pipe, Schedules 40 and 80
Chlorinated Poly(Vinyl Chloride) (CPVC) pipes are usable for water distribution at elevated temperatures.
- Insert PVC and CPVC pipes in Sketchup 3D models with the free Engineering ToolBox Plugin!
| Nominal Pipe Size (inches) | Outside Diameter (inches) | Minimum Wall Thickness (inches) | Inside Diameter*) (inches) | Weight (lb/ft) | |
| PVC | CPVC | ||||
| 1/2 | 0.840 | 0.109 | 0.622 | 0.16 | 0.17 |
| 3/4 | 1.050 | 0.113 | 0.824 | 0.21 | 0.23 |
| 1 | 1.315 | 0.133 | 1.049 | 0.32 | 0.34 |
| 1 1/4 | 1.660 | 0.140 | 1.380 | 0.43 | 0.46 |
| 1 1/2 | 1.900 | 0.145 | 1.610 | 0.51 | 0.55 |
| 2 | 2.375 | 0.154 | 2.067 | 0.68 | 0.74 |
| 2 1/2 | 2.875 | 0.203 | 2.469 | 1.07 | 1.18 |
| 3 | 3.500 | 0.216 | 3.068 | 1.41 | 1.54 |
| 4 | 4.500 | 0.237 | 4.026 | 2.01 | 2.20 |
| 5 | 5.563 | 0.258 | 5.047 | 2.73 | |
| 6 | 6.625 | 0.280 | 6.065 | 3.53 | 3.86 |
| 8 | 8.625 | 0.322 | 7.981 | 5.39 | 5.81 |
| 10 | 10.750 | 0.365 | 10.020 | 7.55 | 8.24 |
| 12 | 12.750 | 0.406 | 11.938 | 10.01 | 10.89 |
| 14 | 14.000 | 0.437 | 13.124 | 11.80 | |
| 16 | 16.000 | 0.500 | 15.000 |
15.43 |
For sizes 1 1/4" and larger ASTM D1785 Schedule 40 pipe is comparable to ASTM D2665 for DWV applications.
Note that CPVC are available as CTS - Copper Tube Sized - tubes for plumbing.
| PVC | CPVC | ||||
| 1/2 | 0.840 | 0.147 | 0.546 | 0.20 | 0.22 |
| 3/4 | 1.050 | 0.154 | 0.742 | 0.27 | 0.30 |
| 1 | 1.315 | 0.179 | 0.957 | 0.41 | 0.44 |
| 1 1/4 | 1.660 | 0.191 | 1.278 | 0.52 | 0.61 |
| 1 1/2 | 1.900 | 0.200 | 1.500 | 0.67 | 0.74 |
| 2 | 2.375 | 0.218 | 1.939 | 0.95 | 1.02 |
| 2 1/2 | 2.875 | 0.276 | 2.323 | 1.45 | 1.56 |
| 3 | 3.500 | 0.300 | 2.900 | 1.94 | 2.09 |
| 4 | 4.500 | 0.337 | 3.826 | 2.75 | 3.05 |
| 5 | 5.563 | 0.375 | 4.813 | 3.87 | |
| 6 | 6.625 | 0.432 | 5.761 | 5.42 | 5.82 |
| 8 | 8.625 | 0.500 | 7.625 | 8.05 | 8.83 |
| 10 | 10.750 | 0.593 | 9.564 | 12.00 | 13.09 |
| 12 | 12.750 | 0.687 | 11.376 | 16.50 | 18.0 |
| 14 | 14.000 | 0.750 | 12.500 | 19.30 | |
| 16 | 16.000 | 0.843 | 14.314 | 25.44 | |
*) Inside Diameter = Outside Diameter - 2 x Minimum Wall Thickness
- 1 lb = 0.4536 kg
- 1 ft (foot) = 0.3048 m
- 1 in (inch) = 25.4 mm
PVC - Polyvinyl Chloride
PVC is the strongest and one of the most widely used plastic pipe. PVC has poor resistance to solvents and is used for both pressure and non-pressure applications. PVC is approved for potable water systems.
- strong and rigid
- resistant to a variety of acids and bases
- may be damaged by some solvents and chlorinated hydrocarbons
- maximum usable temperature 140 oF (60 oC)
- usable for water, gas and drainage systems
- not usable in hot water systems
| Operating Temp (°F) | Operating Temp (°C) | De-Rating Factor |
| 73 | 22.8 | 1.00 |
| 80 | 26.7 | 0.88 |
| 90 | 32.2 | 0.75 |
| 100 | 37.8 | 0.62 |
| 110 | 43.3 | 0.51 |
| 120 | 48.9 | 0.40 |
| 130 | 54.4 | 0.31 |
| 140 | 60 | 0.22 |
CPVC - Chlorinated Polyvinyl Chloride
CPVC is a chemical modification of PVC, with an extra chlorine atom in its structure that extends the service temperature to about 180 - 200°F (82 - 93°C). Sizes and other properties are very similar to PVC.
| 73 - 80 | 22.8 - 26.7 | 1.00 |
| 90 | 32.2 | 0.91 |
| 100 | 37.8 | 0.82 |
| 110 | 43.3 | 0.72 |
| 120 | 48.9 | 0.65 |
| 130 | 54.4 | 0.57 |
| 140 | 60 | 0.50 |
| 150 | 65.6 | 0.42 |
| 160 | 71.1 | 0.40 |
| 170 | 76.7 | 0.29 |
| 180 | 82.2 | 0.25 |
| 200 | 93.3 | 0.20 |
Note!
- ASTM D2665 covers PVC drain, waste and vent pipe and fittings
- CPVC pipes are available in Copper Tube Sizes (CTS) - in accordance to ASTM D2846 "Standard Specification for Chlorinated Poly(Vinyl Chloride) (CPVC) Plastic Hot- and Cold-Water Distribution Systems".
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASTM D2241 - Poly(Vinyl Chloride) (PVC) Pressure-Rated Pipe (SDR Series) - Dimensions
Dimensions of PVC pipe SDR series.
ASTM D2665 - Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Drain, Waste, and Vent Pipe and Fittings - Dimensions
PVC drain, waste, and vent pipe dimensions.
ASTM D2729 - Poly(Vinyl Chloride) (PVC) Sewer Pipe - Dimensions
Dimensions of Poly(Vinyl Chloride) (PVC) Sewer Pipes with belled end.
Dimensions of CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
ASTM D3034 PSM PVC Sewer PIpe - Dimensions
Dimensions of PSM PVC sewer pipe.
ASTM F2389 Pressure-rated Polypropylene (PP) - Dimensions
Dimensions of pressure rated PP pipes according ASTM F2389.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
CPVC Pipes - Hanger Spacing
Maximum distance between CPVC pipe supports.
CPVC Pipes - Operating and Collapsing Pressures vs. Schedule and Size
Maximum operating and bursting pressures of CPVC - Chlorinated Poly (Vinyl Chloride) - piping systems.
CPVC Tubes - Pressure and Temperature Ratings
CTS (Copper Tube Sized) CPVC (Chlorinated Poly Vinyl Chloride) tubes temperature and pressure ratings.
CTS (Copper Tube Sized) and CPVC Tubes - Friction Loss vs. Water Flow
Volume flow and pressure loss in CTS - Copper Tube Sized CPVC (Chlorinated Poly Vinyl Chloride) tubes.
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing.
Dimensions of PVC pipes according EN 1401.
EN 1452 - Unplasticized Poly Vinyl Chloride (PVC-U) - Dimensions
Dimensions of PVC-U pipe according EN 1452.
EN 1453 - PVC Piping with Structured Walls - Dimensions
Dimensions of PVC pipes with structured walls according EN 1453.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
ISO 11922 - Thermoplastics Pipes for the Conveyance of Fluids - Dimensions
ISO 161 - Thermoplastics Pipes - Dimensions
Dimensions of thermoplastic pipes according ISO 161.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe and Tubing Formulas
Pipe and Tube Equations - moment of inertia, section modulus, traverse metal area, external pipe surface and traverse internal area - imperial units
Pipe Weight Calculator
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Piping Materials - Cost Ratios
Plastic Pipes - Friction Head Loss vs. Water Flow
PVC Pipes - Equivalent Length and Pressure Loss in Fittings
Minor loss in PVC and CPVC fittings expressed as equivalent length of straight pipe.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 40 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Thermoplastic Pipes - Support Distance vs. Temperature
Maximum space between supports for PVC, CPVC, PVDF and PP pipes vs. temperature.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
