Ice Loaded Pipelines
Weight load on ice coated horizontal pipe lines:
- 1 lb/ft = 1.49 kg/m
• Piping Systems
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Ice - Properties
Properties like Youngs modulus, tensile strength, compressive strength and fracture of toughness for ice.
Ice - Safe Load vs. Thickness
Safe loads vs. thickness for clear and solid ice.
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Pipe Weight Calculator
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Steel Pipes - Weight
