PE pipes are produced in different pressure grades - PN grades - indicating the pressure in bars the pipe can support with water at 20 oC.
The pressure grades available according to European standards are
Bending PE pipe calculator.
Ice coat weigth on horizontal pipe lines.
Nominal weights of welded steel pipes ranging 26 - 60 inches.
