Welded Steel Pipes - Weights
Weights of welded steel pipes ranging size 26 - 60 inches with wall thickness 1/4 to 1 1/2:
• Dimensions
ANSI Schedule 80 Steel Pipes - Dimensions
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipes - Dimensions
PE - Polyethylene High Density Pipes - Weights
Weight of polyethylene pipes - metric units.
Pipe Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Pipe Weight Calculator
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Schedule - Terminology
Introduction to the schedule terminology of pipes.
Weight vs. Gauges Chart
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
