Based on ASTM A53 - Standard Specification for Pipe, Steel, Black and Hot-Dipped, Zinc-Coated, Welded and Seamless.
For full table with Length vs. External and Internal Surface, Volume, Weight and Number of Threads - rotate the screen!
ANSI Schedule 80 Steel Pipes - Dimensions
Pipe Size
(in)
Diameter
(in)
Nominal Thickness
(in)
Transverse Areas
(in2)
Length of Pipe
(per sq. foot of)
Volume
(ft3/ft)
WeightNumber of Threads per inch of Screw
ExternalInternalExternalInternalSteelExternal Surface
(ft)
Internal Surface (ft)lb/ftkg/m
1/8 0.41 0.22 0.10 0.13 0.04 0.09 9.43 17.75 0.0003 0.31 0.47 27
¼ 0.54 0.30 0.12 0.23 0.07 0.16 7.07 12.65 0.0005 0.54 0.80 18
3/8 0.68 0.42 0.13 0.36 0.14 0.22 5.66 9.03 0.0010 0.74 1.10 18
½ 0.84 0.55 0.15 0.55 0.23 0.32 4.55 7.00 0.0016 1.00 1.49 14
¾ 1.05 0.74 0.15 0.87 0.43 0.43 3.64 5.15 0.0030 1.47 2.19 14
1 1.32 0.96 0.18 1.36 0.72 0.64 2.90 4.00 0.0050 2.17 3.23 11 ½
1 ¼ 1.66 1.28 0.19 2.16 1.28 0.88 2.30 2.99 0.0089 3.00 4.46 11 ½
1 ½ 1.90 1.50 0.20 2.84 1.77 1.07 2.01 2.54 0.0123 3.65 5.43 11 ½
2 2.38 1.94 0.22 4.43 2.95 1.48 1.61 1.97 0.0205 5.02 7.47 11 ½
2 ½ 2.88 2.32 0.28 6.49 4.24 2.25 1.33 1.65 0.0294 7.66 11.40 8
3 3.50 2.90 0.30 9.62 6.61 3.02 1.09 1.32 0.0459 10.30 15.33 8
3 ½ 4.00 3.36 0.32 12.56 8.89 3.68 0.95 1.14 0.0617 12.50 18.60 8
4 4.50 3.83 0.34 15.90 11.50 4.41 0.85 1.00 0.08 14.90 22.17 8
5 5.56 4.81 0.38 24.30 18.19 6.11 0.69 0.79 0.1263 20.80 30.95 8
6 6.63 5.76 0.43 34.47 26.07 8.30 0.58 0.67 0.1810 28.60 42.56 8
8 8.63 7.63 0.50 58.42 45.66 12.76 0.44 0.50 0.3171 43.40 64.59 8
10 10.75 9.56 0.59 90.76 71.84 18.92 0.36 0.40 0.4989 64.40 95.84 8
12 12.75 11.38 0.69 127.64 101.64 26.00 0.30 0.34 0.7058 88.60 131.85
14 14.00 12.50 0.75 153.94 122.72 31.22 0.27 0.31 0.8522 107.00 159.23
16 16.00 14.31 0.84 201.05 160.92 40.13 0.24 0.26 1.1170 137.00 203.88
18 18.00 16.13 0.94 254.85 204.24 50.61 0.21 0.24 1.4180 171.00 254.48
20 20.00 17.94 1.03 314.15 252.72 61.43 0.19 0.21 1.7550 209.00 311.03
24 24.00 21.56 1.22 452.40 365.22 87.18 0.16 0.17 2.5360 297.00 441.99
ASTM A53 pipe  - also referred to as ASME SA53 pipe - is intended for mechanical and pressure applications. Can be used in steam, water, gas and air lines. Suitable for welding and forming like coiling, bending and flanging.
  • 1 in2 = 645.2 mm2 = 6.452 cm2 = 6.452×10-4 m2
  • 1 ft (foot) = 0.3048 m
Piping Codes and Standards
Piping Systems
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
ASTM A53 B Carbon Steel Pipes - Allowable Pressure vs. Schedule and Size
Maximum working pressure of carbon steel pipe at temperature 400oF.
ASTM International - Standards for Steel Pipes, Tubes and Fittings
The ASTM standards covers various types of steel pipes, tubes and fittings for high-temperature services, ordinary use and special applications such as fire protection use
EN 10241 - Steel Threaded Pipe Fittings
EN 10241 specifies requirements for screw threaded fittings.
Hot Water Heating System Online Design Application
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Schedule - Terminology
Introduction to the schedule terminology of pipes.
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Pipes - Heat Loss Diagram
Heat loss from steel pipes and tubes - dimensions 1/2 to 12 inches.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes - Weight
Steel Pipes Schedule 40 - Friction Loss vs. Water Flow Diagram
Friction loss and velocity diagrams - in imperial (psi/100 ft, ft/s) and SI (Pa/100m, m/s) units.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Steel Pipes Schedule 80 - Friction Loss vs. Water Flow Diagram
Water flow in steel pipes schedule 80 - pressure drop and velocity diagrams in SI and Imperial units.
Threaded & Socket Welded Steel Fittings - Pressure Classes vs. Schedules
Pressure classes, schedules and weights of pipes for threaded & socket welded fittings.
Vacuum Pumps - Exhaust Pipe Capacities
Capacities of vacuum pump exhaust pipes.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
