Steel Pipes - Maximum Water Flow Capacities vs. Size
No single recommendation will be correct for all possible circumstances, but the table below can be used as a general guidance for water flow capacity in Steel pipes schedule 40.
| Pipe Size (inch) | Maximum Flow (gal/min) | Velocity (ft/s) | Head Loss (ftH2O/100ft, m/100m) |
| 2 | 45 | 4.3 | 3.9 |
| 2 1/2 | 75 | 5.0 | 4.1 |
| 3 | 130 | 5.6 | 3.9 |
| 4 | 260 | 6.6 | 4.0 |
| 6 | 800 | 8.9 | 4.0 |
| 8 | 1600 | 10.3 | 3.8 |
| 10 | 3000 | 12.2 | 4.0 |
| 12 | 4700 | 13.4 | 4.0 |
| 14 | 6000 | 14.2 | 4.0 |
| 16 | 8000 | 14.5 | 3.5 |
| 18 | 10000 | 14.3 | 3.0 |
| 20 | 12000 | 13.8 | 2.4 |
| 24 | 18000 | 14.4 | 2.1 |
It is common to use maximum friction (head) loss to determine maximum flow and velocities in pipes. But be aware of that with
- increased friction loss - the installation cost is decreased and the operating cost is increased
- decreased friction loss - the installation cost is increased and the operating cost decreased
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
AWWA C115 - Ductile-Iron Threaded Pipe - Dimensions
Dimensions of threaded ductile-iron pipe according AWWA C115.
AWWA C151 - Ductile-Iron Pipe Centrifugally Cast - Dimensions
Dimensions of ductile-iron pipes according AWWA C151/A.21.51.
EN 10241 - Steel Threaded Pipe Fittings
EN 10241 specifies requirements for screw threaded fittings.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Pipes - Relative Capacity
Relative capacity between larger and smaller pipes.
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes Schedule 40 - Friction Loss vs. Water Flow Diagram
Friction loss and velocity diagrams - in imperial (psi/100 ft, ft/s) and SI (Pa/100m, m/s) units.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Steel Pipes Schedule 80 - Friction Loss vs. Water Flow Diagram
Water flow in steel pipes schedule 80 - pressure drop and velocity diagrams in SI and Imperial units.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
