Water Flow in Tubes - Reynolds Number
Turbulent or laminar flow is determined by the dimensionless Reynolds Number which is important when analyzing fluid flow where there is a substantial velocity gradient (i.e. shear). The Reynolds number indicates the relative significance of the viscous effect compared to the inertia effect and the number is proportional to the inertial force divided by the viscous force.
- Reynold's Number - a definition
The flow is
- laminar when Re < 2300
- transient when 2300 < Re < 4000
- turbulent when 4000 < Re
Reynolds Number for one liter of water at approximately 20 oC (68 oF) flowing through pipes of different dimensions:
Pipe Size | ||||||||||
(inches) | 1 | 1 1/2 | 2 | 3 | 4 | 6 | 8 | 10 | 12 | 18 |
(mm) | 25 | 40 | 50 | 75 | 100 | 150 | 200 | 250 | 300 | 450 |
Reynolds number with 1 liter/min |
835 | 550 | 420 | 280 | 210 | 140 | 105 | 85 | 70 | 46 |
Reynolds number with 1 gal/min |
3180 | 2090 | 1600 | 1060 | 780 | 570 | 400 | 320 | 265 | 175 |
Note that the water viscosity varies with temperature.
- the kinematic viscosity of water at 20 oC - used to calculate the table above - is 1.004·10-6 m2/s
- at 0 oC the kinematic viscosity is 1.787·10-6 m2/s - the Reynolds values in the table above must be multiplicated with 1.004 / 1.787 = 0.56
- at 100 oC the kinematic viscosity is 0.29·10-6 m2/s - the values in the table above must be multiplicated with 1.004 / 0.29 = 3.46
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Fluid Flow - Hydraulic Diameter
Calculate hydraulic diameter for pipes and ducts.
Hazen-Williams Water Flow Formula: Head Loss, Data, Charts & Calculator
Hoses - Pressure Loss vs. Water Flow
Pressure loss in hoses due to water flow and friction.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
