Water Flow - Max. Delivery Velocity vs. Pipe Size
As a rule of thumb the following velocities can be used in design of piping and pumping systems for water:
NPS | Max. Delivery Velocity | ||
inches | mm | m/s | ft/s |
1 | 25 | 1 | 3.5 |
2 | 50 | 1.1 | 3.6 |
3 | 75 | 1.15 | 3.8 |
4 | 100 | 1.25 | 4 |
6 | 150 | 1.5 | 4.7 |
8 | 200 | 1.75 | 5.5 |
10 | 250 | 2 | 6.5 |
12 | 300 | 2.65 | 8.5 |
More about Water Systems, Pumps or Piping Systems.
• Piping Systems
• Pumps
• Water Systems
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
PVC Pipes Schedule 80 - Friction Loss vs. Water Flow
Water flow in thermoplastic PVC and CPVC pipes Schedule 80 - friction loss (ft/100 ft, psi/100 ft) and flow velocities at dimensions ranging 1/2 to 16 inches.
Steel Pipes - Maximum Water Flow Capacities vs. Size
Maximum water flow capacities in steel pipes - pipe dimensions ranging 2 - 24 inches.
Steel Pipes Schedule 40 - Velocity Head vs. Water Flow
Velocity head can be used to calculate minor pressure or head loss in fluid flow systems.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
