Water Systems - Maximum Flow Velocities
The fluid flow velocities in water systems should not exceed certain limits to avoid noise and damaging wear and tear of pipes and fittings. The table below can be used as a guide to maximum velocities:
Application | Maximum Velocity | |
(m/s) | (ft/s) | |
General Water Service | 0.9 - 2.4 | 3 - 8 |
Tap water (low noise) | 0.5 - 0.7 | 1.6 - 2.3 |
Tap water | 1.0 - 2.5 | 3.3 - 8.2 |
Cooling water | 1.5 - 2.5 | 4.9 - 8.2 |
Suction boiler feed water | 0.5 - 1.0 | 1.6 - 3.3 |
Discharge boiler feed water | 1.5 - 2.5 | 4.9 - 8.2 |
Condensate | 1.0 - 2.0 | 3.3 - 6.5 |
Process water | 1.5 - 3 | 5 - 10 |
Pump discharge | 1.5 - 3 | 5 - 10 |
Pump suction | 0.9 - 2.4 | 3 - 8 |
Heating circulation | 1.0 - 3.0 | 3.3 - 9.8 |
• Water Systems
Hot and cold water service systems - design properties, capacities, sizing and more.
Boiler Feed Water - Chemistry and Impurity Limits
ABMA recommended feed water chemistry limits for steam boilers.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Cooling Water - Pipe Lines
Sizing cooling water pipe lines - maximum allowable flow, velocity and pressure drops.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Hot Water Heating Systems - Online Design Application
Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge length vs. volume flow from water filled horizontal pipes.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipes - Fluid Flow Velocities
Calculate fluid velocity and volume flow in pipes and tubes.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water Flow - Max. Delivery Velocities vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
