Boiler Feed Water - Chemistry and Impurity Limits
The maximum recommended
  • Total Dissolved Solids (TDS)
  • total alkalinity
  • total dissolved solids
 according to ABMA - American Boiler Manufacturers Association:
Boiler Feed Water - Chemistry Limits
Boiler Operating Pressure
(psig)
(bar)
- TDS -
(ppm)
Total Alkalinity
(ppm)
Total Suspended Solids
(ppm)
0 - 50
0 - 3.5
2500 500
50 - 300
3.5 - 20
3500 700 15
300 - 450
20 - 30
3000 600 10
450 - 600
30 - 40
2500 500 8
600 - 750
40 - 50
1000 200 3
750 - 900
50 - 60
750 150 2
900 - 1000
60 - 70
625 125 1
Maximum Allowable Impurities in Boiler Water
Boiler Feed Water - Maximum Allowable Impurities
ChemicalSymbolMaximum Concentration
(ppm)
Sodium sulphite NA2SO3 1.0
Sodium chloride NaCl 10.0
Sodium phosphate NA3PO4 25.0
Sodium sulphate NA2SO4 25.0
Silica oxide SiO2 0.20
Steam and Condensate
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
Boiler - Efficiency
Combustion gross and net calorific value.
Boiler Blowdown
Boiler Blowdown Rate
Calculate boiler blowdown rate.
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Boiler Water - Total Dissolved Solids (TDS)
Impurities from the feedwater will concentrate in the boiling water.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Steam Boiler Rating vs. Feed Water Temperature
Boiler output vs. feed water temperature.
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
