Boiler Blowdown Rate
A blowdown of the boiler is a routine operation necessary due to the increased concentration of Total Dissolved Solids - TDS - in the boiler water when producing steam.
The blow down rate of a boiler depends on
- steam consumption (steam used in the process and not returned as condensate to the boiler)
- concentration of impurities in the feed water
- maximum allowable TDS in the boiler
The blowdown rate can be calculated as
qBD= qS fc / (bc - fc) (1)
qBD = blowdown rate (kg/h)
qS = steam consumption (kg/h)
fc = Total Dissolved Solids - TDS - in the feed water (ppm)
bc = maximum allowable Total Dissolved Solids - TDS - in the boiler water (ppm)
• Steam and Condensate
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
Boiler Blowdown
Boiler Capacities
Steam boilers output can be expressed in Boiler Horsepower, MBTU or in Pounds of Steam delivered per hour.
Boiler Feed Water - Chemistry and Impurity Limits
ABMA recommended feed water chemistry limits for steam boilers.
Boiler Water - Total Dissolved Solids (TDS)
Impurities from the feedwater will concentrate in the boiling water.
Boilers - Classification
Classification of boilers according the ASME Boiler and Pressure Vessel Code.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Steam Boiler Rating vs. Feed Water Temperature
Boiler output vs. feed water temperature.
Calculate the stress in steam boiler shells caused by steam pressure.
