Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
To avoid cavitation in a feed pump the suction lift and pressure head should not exceed the limits indicated below:
Temperature of Feeding Water | Max Suction Lift | Minimum Pressure Head | |||
(oC) | (oF) | (m) | (ft) | (m) | (ft) |
55 | 130 | 3 | 10 | ||
65 | 150 | 2 | 7 | ||
77 | 170 | 0.6 | 2 | ||
80 | 175 | 0 | 0 | 0 | 0 |
87 | 190 | 1.5 | 5 | ||
95 | 200 | 3.5 | 10 | ||
99 | 210 | 4.5 | 15 | ||
100 | 212 | 5 | 17 |
For water with temperature above 80 oC (175 oF) it is necessary with a positive pressure head - and the pump is located in an elevation below the water or condensate receiver.
In steam distribution systems its common with open vented condensate receivers with temperatures close to 100 oC (212 oF). This is true especially in systems where most of the steam consumed is returned as hot condensate, but also in systems where the make up water is heated to reduce the amount of air dissolved in the water.
- Recommended Suction Flow Velocity for Boiling Fluids - Recommended flow velocity for the pump suction side.
- Recommended Delivery Flow Velocity for Boiling Liquids - Flow velocity normally required on the delivery side of the pump in systems with boiling liquids.
- 1 ft (foot) = 0.3048 m
• Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
• Steam and Condensate
ASME - International Boiler and Pressure Vessel Code
The International Boiler and Pressure Vessel Code safety rules governing design, fabrication, and inspection of boilers and pressure vessels, and nuclear power plant components during construction.
Boiler Blowdown Rate
Calculate boiler blowdown rate.
Boiler Feed Water - Chemistry and Impurity Limits
ABMA recommended feed water chemistry limits for steam boilers.
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Flash Steam Generation - Fundamental Physics
Tutorial to the basic physics behind flash steam generation
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Water - Boiling Points vs. Altitude
Elevation above sea level and the boiling point of water.
