Water - Boiling Points vs. Altitude
The boiling point of water decreases with altitude:
| Altitude - compared to Sea Level | Boiling Point | ||
| (ft) | (m) | (oF) | (oC) |
| -1000 | -305 | 213.9 | 101.1 |
| -750 | -229 | 213.5 | 100.8 |
| -500 | -152 | 213.0 | 100.5 |
| -250 | -76 | 212.5 | 100.3 |
| 0 | 0 | 212.0 | 100.0 |
| 250 | 76 | 211.5 | 99.7 |
| 500 | 152 | 211.0 | 99.5 |
| 750 | 229 | 210.5 | 99.2 |
| 1000 | 305 | 210.1 | 98.9 |
| 1250 | 381 | 209.6 | 98.6 |
| 1500 | 457 | 209.1 | 98.4 |
| 1750 | 533 | 208.6 | 98.1 |
| 2000 | 610 | 208.1 | 97.8 |
| 2250 | 686 | 207.6 | 97.6 |
| 2500 | 762 | 207.2 | 97.3 |
| 2750 | 838 | 206.7 | 97.1 |
| 3000 | 914 | 206.2 | 96.8 |
| 3250 | 991 | 205.7 | 96.5 |
| 3500 | 1067 | 205.3 | 96.3 |
| 3750 | 1143 | 204.8 | 96.0 |
| 4000 | 1219 | 204.3 | 95.7 |
| 4250 | 1295 | 203.8 | 95.5 |
| 4500 | 1372 | 203.4 | 95.2 |
| 4750 | 1448 | 202.9 | 94.9 |
| 5000 | 1524 | 202.4 | 94.7 |
| 5250 | 1600 | 202.0 | 94.4 |
| 5500 | 1676 | 201.5 | 94.2 |
| 5750 | 1753 | 201.0 | 93.9 |
| 6000 | 1829 | 200.6 | 93.6 |
| 6250 | 1905 | 200.1 | 93.4 |
| 6500 | 1981 | 199.6 | 93.1 |
| 6750 | 2057 | 199.2 | 92.9 |
| 7000 | 2134 | 198.7 | 92.6 |
| 7250 | 2210 | 198.2 | 92.4 |
| 7500 | 2286 | 197.8 | 92.1 |
| 7750 | 2362 | 197.3 | 91.8 |
| 8000 | 2438 | 196.9 | 91.6 |
| 8250 | 2515 | 196.4 | 91.3 |
| 8500 | 2591 | 196.0 | 91.1 |
| 8750 | 2667 | 195.5 | 90.8 |
| 9000 | 2743 | 195.0 | 90.6 |
| 9250 | 2819 | 194.6 | 90.3 |
| 9500 | 2896 | 194.1 | 90.1 |
| 9750 | 2972 | 193.7 | 89.8 |
| 10000 | 3048 | 193.2 | 89.6 |
| 10250 | 3124 | 192.8 | 89.3 |
| 10500 | 3200 | 192.3 | 89.1 |
| 10750 | 3277 | 191.9 | 88.8 |
| 11000 | 3353 | 191.4 | 88.6 |
| 11250 | 3429 | 191.0 | 88.3 |
| 11500 | 3505 | 190.5 | 88.1 |
| 11750 | 3581 | 190.1 | 87.8 |
| 12000 | 3658 | 189.7 | 87.6 |
| 12250 | 3734 | 189.2 | 87.3 |
| 12500 | 3810 | 188.8 | 87.1 |
| 12750 | 3886 | 188.3 | 86.8 |
| 13000 | 3962 | 187.9 | 86.6 |
| 13250 | 4037 | 187.4 | 86.4 |
| 13500 | 4115 | 187.0 | 86.1 |
| 13750 | 4191 | 186.6 | 85.9 |
| 14000 | 4267 | 186.1 | 85.6 |
| 14250 | 4343 | 185.7 | 85.4 |
| 14500 | 4420 | 185.3 | 85.1 |
| 14750 | 4496 | 184.8 | 84.9 |
| 15000 | 4572 | 184.4 | 84.7 |
| 15250 | 4648 | 184.0 | 84.4 |
| 15500 | 4724 | 183.5 | 84.2 |
| 15750 | 4801 | 183.1 | 83.9 |
| 16000 | 4877 | 182.7 | 83.7 |
| 16250 | 4953 | 182.2 | 83.5 |
| 16500 | 5029 | 181.8 | 83.2 |
| 16750 | 5105 | 181.4 | 83.0 |
| 17000 | 5182 | 180.9 | 82.7 |
| 17250 | 5258 | 180.5 | 82.5 |
| 17500 | 5334 | 180.1 | 82.3 |
| 17750 | 5410 | 179.7 | 82.0 |
| 18000 | 5486 | 179.2 | 81.8 |
| 18250 | 5563 | 178.8 | 81.6 |
| 18500 | 5639 | 178.4 | 81.3 |
| 18750 | 5715 | 178.0 | 81.1 |
| 19000 | 5791 | 177.6 | 80.9 |
| 19250 | 5867 | 177.1 | 80.6 |
| 19500 | 5944 | 176.7 | 80.4 |
| 19750 | 6020 | 176.3 | 80.2 |
| 20000 | 6096 | 175.9 | 79.9 |
| 20250 | 6172 | 175.5 | 79.7 |
| 20500 | 6248 | 175.1 | 79.5 |
| 20750 | 6325 | 174.7 | 79.3 |
| 21000 | 6401 | 174.2 | 79.0 |
| 21250 | 6477 | 173.8 | 78.8 |
| 21500 | 6553 | 173.4 | 78.6 |
| 21750 | 6629 | 173.0 | 78.3 |
| 22000 | 6706 | 172.6 | 78.1 |
| 22250 | 6782 | 172.2 | 77.9 |
| 22500 | 6858 | 171.8 | 77.7 |
| 22750 | 6934 | 171.4 | 77.4 |
| 23000 | 7010 | 171.0 | 77.2 |
| 23250 | 7087 | 170.6 | 77.0 |
| 23500 | 7163 | 170.2 | 76.8 |
| 23750 | 7239 | 169.8 | 76.5 |
| 24000 | 7315 | 169.4 | 76.3 |
| 24250 | 7391 | 169.0 | 76.1 |
| 24500 | 7468 | 168.6 | 75.9 |
| 24750 | 7544 | 168.2 | 75.6 |
| 25000 | 7620 | 167.8 | 75.4 |
| 25250 | 7696 | 167.4 | 75.2 |
| 25500 | 7772 | 167.0 | 75.0 |
| 25750 | 7849 | 166.6 | 74.8 |
| 26000 | 7925 | 166.2 | 74.5 |
| 26250 | 8001 | 165.8 | 74.3 |
| 26500 | 8077 | 165.4 | 74.1 |
| 26750 | 8153 | 165.0 | 73.9 |
| 27000 | 8230 | 164.6 | 73.7 |
| 27250 | 8306 | 164.2 | 73.5 |
| 27500 | 8382 | 163.8 | 73.2 |
| 27750 | 8458 | 163.4 | 73.0 |
| 28000 | 8534 | 163.1 | 72.8 |
| 28250 | 8611 | 162.7 | 72.6 |
| 28500 | 8687 | 162.3 | 72.4 |
| 28750 | 8763 | 161.9 | 72.2 |
| 29000 | 8839 | 161.5 | 72.0 |
| 29250 | 8916 | 161.1 | 71.7 |
| 29500 | 8992 | 160.7 | 71.5 |
| 29750 | 9068 | 160.4 | 71.3 |
| 30000 | 9144 | 160.0 | 71.1 |
Example - Boiling Point of Water at the top of Mount Everest
The height of Mount Everest in Nepal is 8848 m.
According the table above the boiling point of water is aprox. 72 oC (161.5 oF).
• Boiling Points of Fluids
Barometer - Altitude Compensation
Elevation compensating manometer.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
