When water is heated it reach a temperature - the boiling point - at which the vapor pressure is large enough that bubbles are formed inside the water. The boiling point of water depends on pressure.
Online Water Boiling Point Calculator
The calculator below can be used to calculate the water boiling point at given absolute pressures.
The output temperature is given as °C, °F, K and °R.
Note! Pressure must be within the ranges 1 - 220 bara, 14.7 - 3200 psia, 760 - 165 000 mm Hg or 30 - 6500 in Hg.
Choose the actual unit of pressure:
Boiling points of water at absolute pressures ranging from 1 to 70 bara or 14.7 to 1000 psia are indicated in the figures and tables below:
See also other properties of Water at varying temperature and pressure : Boiling points at vacuum pressure, Density and specific weight, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Prandtl number, Properties at Gas-Liquid Equilibrium Conditions, Saturation pressure, Specific gravity, Specific heat (heat capacity), Specific volume, Thermal conductivity, Thermal diffusivity and Vapour pressure at gas-liquid equilibrium .
| Absolute pressure | Water boiling point | ||||
| (bara) (1×105 *Pa) | (psia) | (mm Hg) | (in Hg) | (°C) | (°F) |
| 1.013 | 14.7 | 760 | 29.92 | 100 | 212 |
| 1.034 | 15.0 | 776 | 30.54 | 101 | 213 |
| 1.103 | 16.0 | 827 | 32.58 | 102 | 216 |
| 1.172 | 17.0 | 879 | 34.61 | 104 | 219 |
| 1.241 | 18.0 | 931 | 36.65 | 106 | 222 |
| 1.310 | 19.0 | 983 | 38.68 | 107 | 225 |
| 1.379 | 20.0 | 1034 | 40.72 | 109 | 228 |
| 1.517 | 22.0 | 1138 | 44.79 | 112 | 233 |
| 1.655 | 24.0 | 1241 | 48.86 | 114 | 238 |
| 1.793 | 26.0 | 1345 | 52.94 | 117 | 242 |
| 1.931 | 28.0 | 1448 | 57.01 | 119 | 246 |
| 2.068 | 30.0 | 1551 | 61.08 | 121 | 250 |
| 2.206 | 32.0 | 1655 | 65.15 | 123 | 254 |
| 2.344 | 34.0 | 1758 | 69.22 | 125 | 258 |
| 2.482 | 36.0 | 1862 | 73.30 | 127 | 261 |
| 2.620 | 38.0 | 1965 | 77.37 | 129 | 264 |
| 2.758 | 40.0 | 2069 | 81.44 | 131 | 267 |
| 2.896 | 42.0 | 2172 | 85.51 | 132 | 270 |
| 3.034 | 44.0 | 2275 | 89.58 | 134 | 273 |
| 3.172 | 46.0 | 2379 | 93.66 | 135 | 276 |
| 3.309 | 48.0 | 2482 | 97.73 | 137 | 279 |
| 3.447 | 50.0 | 2586 | 101.8 | 138 | 281 |
| 3.585 | 52.0 | 2689 | 105.9 | 140 | 284 |
| 3.723 | 54.0 | 2793 | 109.9 | 141 | 286 |
| 3.861 | 56.0 | 2896 | 114.0 | 142 | 288 |
| 3.999 | 58.0 | 2999 | 118.1 | 144 | 291 |
| 4.137 | 60.0 | 3103 | 122.2 | 145 | 293 |
| 4.275 | 62.0 | 3206 | 126.2 | 146 | 295 |
| 4.413 | 64.0 | 3310 | 130.3 | 147 | 297 |
| 4.551 | 66.0 | 3413 | 134.4 | 148 | 299 |
| 4.688 | 68.0 | 3517 | 138.4 | 149 | 301 |
| 4.826 | 70.0 | 3620 | 142.5 | 151 | 303 |
| 4.964 | 72.0 | 3723 | 146.6 | 152 | 305 |
| 5.102 | 74.0 | 3827 | 150.7 | 153 | 307 |
| 5.240 | 76.0 | 3930 | 154.7 | 154 | 309 |
| 5.378 | 78.0 | 4034 | 158.8 | 155 | 310 |
| 5.516 | 80.0 | 4137 | 162.9 | 156 | 312 |
| 5.654 | 82.0 | 4241 | 167.0 | 157 | 314 |
| 5.792 | 84.0 | 4344 | 171.0 | 158 | 316 |
| 5.929 | 86.0 | 4447 | 175.1 | 158 | 317 |
| 6.067 | 88.0 | 4551 | 179.2 | 159 | 319 |
| 6.205 | 90.0 | 4654 | 183.2 | 160 | 320 |
| 6.343 | 92.0 | 4758 | 187.3 | 161 | 322 |
| 6.481 | 94.0 | 4861 | 191.4 | 162 | 323 |
| 6.619 | 96.0 | 4965 | 195.5 | 163 | 325 |
| 6.757 | 98.0 | 5068 | 199.5 | 164 | 326 |
| 6.895 | 100 | 5171 | 203.6 | 164 | 328 |
| 7.239 | 105 | 5430 | 213.8 | 166 | 331 |
| 7.584 | 110 | 5689 | 224.0 | 168 | 335 |
| 7.929 | 115 | 5947 | 234.1 | 170 | 338 |
| 8.274 | 120 | 6206 | 244.3 | 172 | 341 |
| 10.34 | 150 | 7757 | 305.4 | 181 | 359 |
| 12.07 | 175 | 9050 | 356.3 | 189 | 372 |
| 13.79 | 200 | 10343 | 407.2 | 194 | 382 |
| 15.51 | 225 | 11636 | 458.1 | 200 | 392 |
| 17.24 | 250 | 12929 | 509.0 | 205 | 401 |
| 18.96 | 275 | 14222 | 559.9 | 210 | 410 |
| 20.68 | 300 | 15514 | 610.8 | 214 | 417 |
| 22.41 | 325 | 16807 | 661.7 | 218 | 425 |
| 24.13 | 350 | 18100 | 712.6 | 222 | 432 |
| 25.86 | 375 | 19393 | 763.5 | 226 | 438 |
| 27.58 | 400 | 20686 | 814.4 | 229 | 445 |
| 29.30 | 425 | 21979 | 865.3 | 233 | 451 |
| 31.03 | 450 | 23272 | 916.2 | 236 | 456 |
| 32.75 | 475 | 24565 | 967.1 | 239 | 462 |
| 34.47 | 500 | 25857 | 1018 | 242 | 467 |
| 36.20 | 525 | 27150 | 1069 | 245 | 472 |
| 37.92 | 550 | 28443 | 1120 | 247 | 477 |
| 39.64 | 575 | 29736 | 1171 | 250 | 482 |
| 41.37 | 600 | 31029 | 1222 | 252 | 486 |
| 43.09 | 625 | 32322 | 1273 | 255 | 491 |
| 44.82 | 650 | 33615 | 1323 | 257 | 495 |
| 46.54 | 675 | 34908 | 1374 | 260 | 499 |
| 48.26 | 700 | 36200 | 1425 | 262 | 503 |
| 49.99 | 725 | 37493 | 1476 | 264 | 507 |
| 51.71 | 750 | 38786 | 1527 | 266 | 511 |
| 53.43 | 775 | 40079 | 1578 | 268 | 515 |
| 55.16 | 800 | 41372 | 1629 | 270 | 518 |
| 56.88 | 825 | 42665 | 1680 | 272 | 522 |
| 58.61 | 850 | 43958 | 1731 | 274 | 525 |
| 60.33 | 875 | 45251 | 1782 | 276 | 529 |
| 62.05 | 900 | 46543 | 1832 | 278 | 532 |
| 65.50 | 950 | 49129 | 1934 | 281 | 539 |
| 68.95 | 1000 | 51715 | 2036 | 285 | 545 |
| 75.06 | 1089 | 56301 | 2217 | 290 | 555 |
| 84.64 | 1228 | 63485 | 2499 | 298 | 570 |
| 98.78 | 1433 | 74091 | 2917 | 310 | 590 |
| 114.6 | 1662 | 85965 | 3384 | 321 | 610 |
| 127.9 | 1854 | 95895 | 3775 | 329 | 625 |
| 147.3 | 2136 | 110462 | 4349 | 341 | 645 |
| 163.3 | 2369 | 122493 | 4823 | 349 | 660 |
| 186.8 | 2710 | 140127 | 5517 | 360 | 680 |
| 213.5 | 3096 | 160131 | 6304 | 371 | 700 |
| 222.4 | 3226 | 166829 | 6568 | 374 | 706 |
- T (oC) = 5/9 (T (oF) - 32)
- 1 psi (lb/in2) = 6,894.76 Pa (N/m2) = 0.068948 bar = 51.7149 mm Hg = 2.03602 in Hg
See Water and Heavy Water - for thermodynamic properties.
See also Water Density, specific weight and thermal expansion coefficient, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of Vaporization, Ionization Constant, pKw , of normal and heavy water, Pressure and Boiling Points, Specific gravity, Specific heat (heat capacity) and Specific volume for online calculatores, figures and tables.
• Boiling Points of Fluids
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Boiling Liquids - Max Pumping Flow Velocities
Recommended max flow velocity on the delivery (pressure) side when pumping boiling liquids.
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Water - Boiling Points vs. Altitude
Elevation above sea level and the boiling point of water.
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
