Specific volume is the inverse of density, or the ratio of the volume to the mass of a substance:
v = V / m
= 1 / ρ (1)
v = specific volume, units typically (cm3/g) or (ft3/lb)
V = volume, units typically (cm3) or (ft3)
m = mass, units typically (g) or (lb)
ρ = density, units typically (g/cm3) or (lb/ft3)
Online Water specific volume Calculator
The calculator below can be used to calculate the liquid water specific volume at given temperatures.
The output specific volume is given as cm3/g, ft3/lb, gal(US liq)/lb and ft3/ sl.
Temperatur must be within the ranges 0-370 °C, 32-700 °F, 273-645 K and 492-1160 °R
The specific volume of water depends on temperature as shown below:
See Water and Heavy Water - thermodynamic properties.
See also Water Boiling points at high pressure, Boiling points at vacuum pressure, Density, specific weight and thermal expansion coefficient, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Saturation pressure, Specific gravity and Specific heat (heat capacity) for online calculatores, and similar figures and tables as shown below.
Water specific volume at temperatures given in degree Celcius:
| Temperature | Specific volume (0-100°C at 1 atm, >100 °C at saturation pressure) | ||
| (°C) | (cm3/g) | (ft3/lb) | (gal(US liq)/lb) |
| 0.1 | 1.00015 | 0.016021 | 0.11981 |
| 1 | 1.00010 | 0.016020 | 0.11981 |
| 4 | 1.00003 | 0.016019 | 0.11982 |
| 10 | 1.00030 | 0.016023 | 0.11979 |
| 15 | 1.00090 | 0.016033 | 0.11972 |
| 20 | 1.00180 | 0.016047 | 0.11961 |
| 25 | 1.00296 | 0.016066 | 0.11947 |
| 30 | 1.00437 | 0.016088 | 0.11931 |
| 35 | 1.00600 | 0.016115 | 0.11911 |
| 40 | 1.00785 | 0.016144 | 0.11889 |
| 45 | 1.00989 | 0.016177 | 0.11865 |
| 50 | 1.01210 | 0.016212 | 0.11839 |
| 55 | 1.01452 | 0.016251 | 0.11811 |
| 60 | 1.01709 | 0.016292 | 0.11781 |
| 65 | 1.01984 | 0.016336 | 0.11750 |
| 70 | 1.02275 | 0.016383 | 0.11716 |
| 75 | 1.02581 | 0.016432 | 0.11681 |
| 80 | 1.02903 | 0.016483 | 0.11645 |
| 85 | 1.03241 | 0.016538 | 0.11607 |
| 90 | 1.03594 | 0.016594 | 0.11567 |
| 95 | 1.03962 | 0.016653 | 0.11526 |
| 100 | 1.04346 | 0.016715 | 0.11484 |
| 110 | 1.05158 | 0.016845 | 0.11395 |
| 120 | 1.06032 | 0.016985 | 0.11301 |
| 140 | 1.07976 | 0.017296 | 0.11097 |
| 160 | 1.10199 | 0.017652 | 0.10874 |
| 180 | 1.12740 | 0.018059 | 0.10629 |
| 200 | 1.15652 | 0.018526 | 0.10361 |
| 220 | 1.19016 | 0.019065 | 0.10068 |
| 240 | 1.22945 | 0.019694 | 0.09746 |
| 260 | 1.27611 | 0.020441 | 0.09390 |
| 280 | 1.33284 | 0.021350 | 0.08990 |
| 300 | 1.40422 | 0.022493 | 0.08533 |
| 320 | 1.49905 | 0.024012 | 0.07994 |
| 340 | 1.63755 | 0.026231 | 0.07317 |
| 360 | 1.89541 | 0.030362 | 0.06322 |
| 373.946 | 3.10559 | 0.049747 | 0.03858 |
Water specific volume at temperatures given in degree Fahrenheit:
| Temperature | Specific volume (0-212°F at 1 atm, >212 °F at saturation pressure) | |||
| (°F) | (ft3/lb) | (gal(US liq)/lb) | (ft3/sl) | (cm3/g) |
| 32.2 | 0.01602 | 0.1198 | 0.5155 | 1.0002 |
| 34 | 0.01602 | 0.1198 | 0.5154 | 1.0001 |
| 39.2 | 0.01602 | 0.1198 | 0.5154 | 1.0000 |
| 40 | 0.01602 | 0.1198 | 0.5154 | 1.0000 |
| 50 | 0.01602 | 0.1199 | 0.5155 | 1.0003 |
| 60 | 0.01603 | 0.1199 | 0.5159 | 1.0010 |
| 70 | 0.01605 | 0.1201 | 0.5164 | 1.0020 |
| 80 | 0.01607 | 0.1202 | 0.5171 | 1.0034 |
| 90 | 0.01610 | 0.1204 | 0.5180 | 1.0050 |
| 100 | 0.01613 | 0.1207 | 0.5190 | 1.0070 |
| 110 | 0.01617 | 0.1209 | 0.5201 | 1.0092 |
| 120 | 0.01620 | 0.1212 | 0.5214 | 1.0116 |
| 130 | 0.01625 | 0.1215 | 0.5227 | 1.0143 |
| 140 | 0.01629 | 0.1219 | 0.5242 | 1.0171 |
| 150 | 0.01634 | 0.1222 | 0.5258 | 1.0202 |
| 160 | 0.01639 | 0.1226 | 0.5274 | 1.0234 |
| 170 | 0.01645 | 0.1230 | 0.5292 | 1.0269 |
| 180 | 0.01651 | 0.1235 | 0.5311 | 1.0305 |
| 190 | 0.01657 | 0.1239 | 0.5331 | 1.0343 |
| 200 | 0.01663 | 0.1244 | 0.5351 | 1.0384 |
| 212 | 0.01671 | 0.1250 | 0.5378 | 1.0435 |
| 220 | 0.01677 | 0.1255 | 0.5396 | 1.0471 |
| 240 | 0.01693 | 0.1266 | 0.5446 | 1.0567 |
| 260 | 0.01710 | 0.1279 | 0.5501 | 1.0675 |
| 280 | 0.01728 | 0.1292 | 0.5558 | 1.0785 |
| 300 | 0.01748 | 0.1307 | 0.5623 | 1.0911 |
| 350 | 0.01799 | 0.1346 | 0.5789 | 1.1232 |
| 400 | 0.01861 | 0.1392 | 0.5987 | 1.1616 |
| 450 | 0.01943 | 0.1453 | 0.6251 | 1.2129 |
| 500 | 0.02044 | 0.1529 | 0.6577 | 1.2761 |
| 550 | 0.02177 | 0.1629 | 0.7004 | 1.3591 |
| 600 | 0.02357 | 0.1763 | 0.7583 | 1.4713 |
| 625 | 0.02491 | 0.1864 | 0.8015 | 1.5552 |
| 650 | 0.02683 | 0.2007 | 0.8631 | 1.6747 |
| 675 | 0.02964 | 0.2217 | 0.9535 | 1.8501 |
| 700 | 0.03380 | 0.2528 | 1.0875 | 2.1101 |
See also Properties of Water - Imperial Units and Water - Thermodynamic Properties - SI units
• Densities
• Steam and Condensate
• Water Systems
Compressed Water - Properties vs. Temperature
Specific volume, enthalpy and entropy of compressed water.
Hydrocarbons - Physical Data
Liquids - Volumetric Expansion Coefficients
Volumetric - or cubical - expansion coefficients for common liquids.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water-Steam Mollier Diagram
