Density of aqueous solutions at 20°C, given as g/cm3:
For full table with Oxalic and Trichloreacetic Acid - rotate the screen!
Mass% | Acetic acid | Citric acid | Formic acid | D-Lactic acid | Oxalic acid | Trichloroacetic acid |
1 | 0.9996 | 1.0022 | 1.0006 | 1.0002 | 1.0030 | 1.0034 |
5 | 1.0052 | 1.0189 | 1.0102 | 1.0086 | 1.0220 | 1.0230 |
10 | 1.0121 | 1.0402 | 1.0224 | 1.0199 | 1.0479 | |
20 | 1.0250 | 1.0858 | 1.0467 | 1.0439 | 1.1035 | |
30 | 1.0369 | 1.1346 | ||||
40 | 1.0474 | 1.0935 | 1.0915 | 1.2188 | ||
50 | 1.0562 | 1.2803 | ||||
60 | 1.1392 | |||||
70 | 1.0673 | 1.1586 | ||||
80 | 1.1848 | |||||
100 | 1.0477 | |||||
Density of acids solved in water at 20°C, given as wt% |
Conversion of the concentration from mass% to mol/kg (moles of solute/kg of water = molality):
1 | 0.168 | 0.053 | 0.219 | 0.112 | 0.112 | 0.062 |
5 | 0.876 | 0.274 | 1.143 | 0.584 | 0.585 | 0.322 |
10 | 1.850 | 0.578 | 2.414 | 1.233 | 0.680 | |
20 | 4.163 | 1.301 | 5.410 | 2.775 | 1.530 | |
30 | 7.137 | 2.231 | ||||
40 | 11.102 | 14.483 | 7.401 | 4.080 | ||
50 | 16.653 | 6.120 | ||||
60 | 16.652 | |||||
70 | 38.857 | 50.692 | ||||
80 | 44.405 | |||||
Mol/kg solution at 20°C |
Conversion of the concentration from mass% to mol/liter (moles of solute/liter of solution = molarity):
1 | 0.166 | 0.052 | 0.217 | 0.111 | 0.111 | 0.061 |
5 | 0.837 | 0.265 | 1.097 | 0.560 | 0.568 | 0.313 |
10 | 1.685 | 0.541 | 2.221 | 1.132 | 0.641 | |
20 | 3.414 | 1.254 | 4.548 | 2.318 | 1.351 | |
30 | 5.180 | 1.772 | ||||
40 | 6.977 | 9.502 | 4.847 | 2.984 | ||
50 | 8.794 | 3.918 | ||||
60 | 7.588 | |||||
70 | 12.441 | 17.619 | ||||
80 | 10.522 | |||||
100 | 17.447 | |||||
Mol/liter solution at 20°C |
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
An introduction to density, specific weight and specific gravity.
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Nomenclature rules for different groups of organic compounds and functional groups, together with examples of use of the rules.
Densities of selected solids.
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Density of sulfuric acid at various temperatures and concentrations.
