Conversion of the concentration from mass% to mol/liter
Be aware of the concentration units in the figures:
wt%: Mass of solute/total mass of solution ×100%
mol/kg: Molality = moles of solute/kg of water
mol/liter: Molarity = moles of solute/liter of solution
Values are tabulated below the figures.
See also density of aqueous solutions of inorganic chlorides, inorganic potassium salts, inorganic sodium salts, organic acids and organic substances as sugars and alcohols.
Density of aqueous solutions at 20°C, given as g/cm3:
For full table with Manganese Sulfate, Nitric Acid, Phosphoric Acid, Silver Nitrate, Sulfuric Acid and Zinc Sulfate - rotate the screen!
Mass% | Ammonia | Ammonium sulfate | Cupper(II) sulfate | Magnesium sulfate | Manganese(II) sulfate | Nitric acid | Phosphoric acid | Silver nitrate | Sulfuric acid | Zinc sulfate |
1 | 0.9938 | 1.0042 | 1.0085 | 1.0084 | 1.008 | 1.0037 | 1.0038 | 1.007 | 1.0049 | 1.0085 |
5 | 0.977 | 1.0279 | 1.0511 | 1.0497 | 1.048 | 1.0257 | 1.0254 | 1.0417 | 1.0318 | 1.0511 |
10 | 0.9575 | 1.0574 | 1.107 | 1.1034 | 1.1012 | 1.0543 | 1.0531 | 1.0882 | 1.0661 | 1.1071 |
20 | 0.9228 | 1.1154 | 1.2198 | 1.2203 | 1.115 | 1.1135 | 1.1942 | 1.1398 | ||
30 | 0.892 | 1.1721 | 1.2961 | 1.1801 | 1.1804 | 1.3204 | 1.2191 | |||
40 | 1.2277 | 1.2466 | 1.2536 | 1.4743 | 1.3028 | |||||
50 | 1.3952 | |||||||||
70 | 1.6105 | |||||||||
100 | 1.8305 | |||||||||
Density at 20°C, given as kg/cm3 |
Conversion of the concentration from mass% to mol/kg (moles of solute/kg of water = molality):
1 | 0.593 | 0.076 | 0.063 | 0.084 | 0.067 | 0.16 | 0.103 | 0.059 | 0.103 | 0.063 |
5 | 3.09 | 0.398 | 0.33 | 0.437 | 0.349 | 0.835 | 0.537 | 0.31 | 0.537 | 0.326 |
10 | 6.524 | 0.841 | 0.696 | 0.923 | 0.736 | 1.763 | 1.134 | 0.654 | 1.133 | 0.688 |
20 | 14.679 | 1.892 | 2.077 | 1.656 | 3.967 | 2.551 | 1.472 | 2.549 | ||
30 | 25.164 | 3.243 | 2.919 | 6.801 | 4.373 | 2.523 | 4.37 | |||
40 | 5.045 | 10.58 | 6.803 | 3.925 | 6.797 | |||||
50 | 10.196 | |||||||||
70 | 23.79 | |||||||||
100 | ||||||||||
Molality at 20°C, given as mol/kg water |
Conversion of the concentration from mass% to mol/liter (moles of solute/liter of solution = molarity):
1 | 0.584 | 0.076 | 0.063 | 0.084 | 0.067 | 0.159 | 0.102 | 0.059 | 0.102 | 0.062 |
5 | 2.868 | 0.389 | 0.329 | 0.436 | 0.347 | 0.814 | 0.523 | 0.307 | 0.526 | 0.326 |
10 | 5.622 | 0.8 | 0.694 | 0.917 | 0.729 | 1.673 | 1.075 | 0.641 | 1.087 | 0.686 |
20 | 10.837 | 1.688 | 2.027 | 1.616 | 3.539 | 2.273 | 1.406 | 2.324 | ||
30 | 15.713 | 2.661 | 2.8 | 5.618 | 3.614 | 2.332 | 3.729 | |||
40 | 3.716 | 7.913 | 5.117 | 3.472 | 5.313 | |||||
50 | 7.113 | |||||||||
70 | 11.494 | |||||||||
100 | 18.663 | |||||||||
Molarity at 20°C, given as mol/l solution |
• Densities
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Concentration Units Converter
Calculator and formulas for conversion between different units of concentration: Molarity, molality, mole fraction, weight percent of solute and grams of solute per liter of solution - descriptive terms for solubility.
Density Converter
Liquid Densities
Liquid-Liquid Solution - Shrinkage and Estimation of Density
It is possible to estimate the density of a liquid-liquid solution from the density of the solute and the solvent. However, due to shrinkage, the estimate will be a bit too low.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Solids - Densities
Densities of selected solids.
Solutions, Molarity and Dilution
Definitions and examples of how to calculate wt%, molarity and how to prepare dilutions.
Sulfuric Acid - Density
Density of sulfuric acid at various temperatures and concentrations.
