Sulfuric Acid - Density
Concentration
(% mass H2SO4)
Density (g/mL)
Temperature (oC)
020406080100
1 1.0074 1.0051 0.9986 0.9895 0.9779 0.9646
20 1.1510 1.1394 1.1275 1.1153 1.1021 1.0885
40 1.3179 1.3028 1.2880 1.2732 1.2589 1.2446
60 1.5154 1.4983 1.4816 1.4656 1.4497 1.4344
80 1.7482 1.7272 1.7069 1.6873 1.6680 1.6493
100 1.8517 1.8305 1.8107 1.7922
Material Properties
Acid and Base pH Indicators
pH range vs. color change for acid and base indicators - together with pKa and structures of the indicators.
Acids - pH Values
pH values of acids like sulfuric, acetic and more..
Inorganic Acids and Bases - pKa Values
Values for the negative logarithm of the acid dissociation constant, pKa, of inorganic acids and bases, as well as hydrated metal ions.
Liquid Densities
pH - Basic (alkaline) vs. Acidic
Introduction to pH - the acidic and basic (alkaline) definition.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Specific Heat of Common Liquids and Fluids
