A major problem in process industry is corrosion of metals in pipes, valves and other parts of the constructions. Acceptable combinations of more or less aggressive fluids and commonly used materials are indicated below.
Note! Remember that corrosion is a complicated issue, depending on the combinations of materials and the fluids, the fluid temperatures, the surrounding environment and the galvanic currents in constructions. The table below must be used with care. Always check with the producer of the material.
For full table with Durimet, Monel, Hasteloy, Titanium, Cobalt Base Alloy and 416 Stainless Steel - rotate the screen!
Fluid | 1)Good 2)Be Careful 3)Not Usable | |||||||||||
Metal | ||||||||||||
Carbon Steel | Cast Iron | 302 and 304 Stainless Steel | 316 Stainless Steel | Bronze | Durimet | Monel | Hasteloy B | Hasteloy C | Titanium | Cobalt base alloy 6 | 416 Stainless Steel | |
Acetaldehyde | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na | 1 | na | na | 1 |
Acetic acid, air free | 3 | 3 | 2 | 2 | 2 | 1 | 2 | 1 | 1 | 1 | 1 | 3 |
Acetic acid, aerated | 3 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 3 |
Acetic acid, vapors | 3 | 3 | 1 | 1 | 2 | 2 | 2 | na | 1 | 1 | 1 | 3 |
Acetone | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Acetylene | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na | 1 | 1 | |
Alcohols | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Aluminum Sulfate | 3 | 3 | 1 | 1 | 2 | 1 | 2 | 1 | 1 | 1 | na | 3 |
Ammonia | 1 | 1 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | 1 | 1 | 1 |
Ammonium chloride | 3 | 3 | 2 | 2 | 2 | 1 | 2 | 1 | 1 | 1 | 2 | 3 |
Ammonium Nitrate | 1 | 3 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | 1 | 1 | 3 |
Ammonium Phosphate | 4 | 3 | 1 | 1 | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 2 |
Ammonium Sulfate | 3 | 3 | 2 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 3 |
Ammonium Sulfite | 3 | 3 | 1 | 1 | 3 | 1 | 3 | na | 1 | 1 | 1 | 2 |
Aniline | 3 | 3 | 1 | 1 | 3 | 1 | 2 | 1 | 1 | 1 | 1 | 3 |
Asphalt | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na | 1 | 1 |
Beer | 2 | 2 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Benzene (benzol) | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Benzoic acid | 3 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | ||
Boric acid | 3 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Butane | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Calcium Chloride (alkaline) | 2 | 2 | 3 | 2 | 3 | 1 | 1 | 1 | 1 | 1 | na | 3 |
Calcium hypochlorite | 3 | 3 | 2 | 2 | 2 | 1 | 2 | 3 | 1 | 1 | na | 3 |
Carbolic acid | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Carbon dioxide, dry | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Carbon dioxide, wet | 3 | 3 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Carbon disulfide | 1 | 1 | 1 | 1 | 3 | 1 | 2 | 1 | 1 | 1 | 1 | 2 |
Carbon tetrachloride | 2 | 2 | 2 | 2 | 1 | 1 | 1 | 2 | 1 | 1 | na | 3 |
Carbonic acid | 3 | 3 | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | ||
Chlorine gas | 1 | 1 | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 2 | 3 |
Chlorine gas, wet | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 2 | 1 | 2 | 3 |
Chlorine, liquid | 3 | 3 | 3 | 3 | 2 | 2 | 3 | 3 | 1 | 1 | 2 | 3 |
Chromic acid | 3 | 3 | 3 | 2 | 3 | 3 | 1 | 3 | 1 | 1 | 2 | 3 |
Citric acid | 3 | 3 | 2 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 2 | |
Coke oven gas | 1 | 1 | 1 | 1 | 2 | 1 | 2 | 1 | 1 | 1 | 1 | 1 |
Copper sulfate | 3 | 3 | 2 | 2 | 2 | 1 | 3 | na | 1 | 1 | na | 1 |
Cottonseed oil | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Creosote | 1 | 1 | 1 | 1 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | |
Ethane | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Ether | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Ethyl chloride | 3 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Ethylene | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Ethylene glycol | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na | na | na | 1 | 1 |
Ferric chloride | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 2 | 1 | 2 | 3 |
Formaldehyde | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Formic acid | 3 | 3 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 3 | 2 | 3 |
R-12 dichlorodifluoromethane wet | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na |
R-12 dichlorodifluoromethane dry | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | na |
Furfural | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Gasoline | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Glucose | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Hydrochloric acid, aerated | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 1 | 2 | 1/2 | 2 | 3 |
Hydrochloric acid, air free | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 1 | 2 | 1/2 | 2 | 3 |
Hydrofluoric acid, aerated | 2 | 3 | 3 | 2 | 3 | 2 | 3 | 1 | 1 | 3 | 2 | 3 |
Hydrofluoric acid, air free | 1 | 3 | 3 | 2 | 3 | 2 | 1 | 1 | 1 | 3 | na | 3 |
Hydrogen | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Hydrogen peroxide | 2 | 1 | 1 | 3 | 1 | 3 | 2 | 2 | 1 | na | 2 | |
Hydrogen sulfide, liquid | 3 | 3 | 1 | 1 | 3 | 2 | 3 | 1 | 1 | 1 | 1 | 3 |
Magnesium Hydroxide | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Mercury | 1 | 1 | 1 | 1 | 3 | 1 | 2 | 1 | 1 | 1 | 1 | 1 |
Methanol | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Methyl ethyl ketone | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Milk | 3 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 3 |
Natural gas | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Nitric acid | 3 | 3 | 1 | 2 | 3 | 1 | 3 | 3 | 2 | 1 | 3 | 3 |
Oleic acid | 3 | 3 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Oxalic acid | 3 | 3 | 2 | 2 | 2 | 1 | 2 | 1 | 1 | 2 | 2 | 2 |
Oxygen | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Petroleum oils | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Phosphoric acid, aerated | 3 | 3 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | 2 | 1 | 3 |
Phosphoric acid, air free | 3 | 3 | 1 | 1 | 3 | 1 | 2 | 1 | 1 | 2 | 1 | 3 |
Phosphoric acid vapors | 3 | 3 | 2 | 2 | 3 | 1 | 3 | 1 | 2 | 3 | 3 | |
Picric acid | 3 | 3 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | na | na | 2 |
Potassium chloride | 2 | 2 | 1 | 1 | 2 | 1 | 2 | 1 | 1 | 1 | na | 3 |
Potassium hydroxide | 2 | 2 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | na | 2 |
Propane | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Rosin | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | |
Silver Nitrate | 3 | 3 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | 1 | 2 | 2 |
Sodium acetate | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Sodium carbonate | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Sodium chloride | 3 | 3 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Sodium chromate | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Sodium hydroxide | 1 | 1 | 1 | 1 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Sodium Hypochlorite | 3 | 3 | 3 | 3 | 3 | 2 | 3 | 3 | 1 | 1 | na | 3 |
Sodium thiosulfate | 3 | 3 | 1 | 1 | 3 | 1 | 3 | 1 | 1 | 1 | na | 2 |
Stannous chloride | 2 | 2 | 3 | 1 | 3 | 1 | 2 | 1 | 1 | 1 | na | 3 |
Stearic acid | 1 | 3 | 1 | 1 | 2 | 1 | 2 | 1 | 1 | 1 | 2 | 2 |
Sulfate liquor | 1 | 1 | 1 | 1 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | |
Sulfur | 1 | 1 | 1 | 1 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Sulfur dioxide, dry | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 2 |
Sulfur trioxide, dry | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 2 |
Sulfuric acid, aerated | 3 | 3 | 3 | 3 | 3 | 1 | 3 | 1 | 1 | 2 | 2 | 3 |
Sulfuric acid, air free | 3 | 3 | 3 | 3 | 2 | 1 | 2 | 1 | 1 | 2 | 2 | 3 |
Sulfurous acid | 3 | 3 | 2 | 2 | 2 | 1 | 3 | 1 | 1 | 1 | 2 | 3 |
Tar | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
Trichloroethylene | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Turpentine | 2 | 2 | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 |
Vinegar | 3 | 3 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | na | 1 | 3 |
Water, steam boiler feeding system | 2 | 3 | 1 | 1 | 3 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Water, distilled | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
Water, sea | 2 | 2 | 2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 3 |
Whiskey | 3 | 3 | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 3 |
Wine | 3 | 3 | 1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 3 |
Zinc chloride | 3 | 3 | 3 | 3 | 3 | 1 | 3 | 1 | 1 | 1 | 2 | 3 |
Zinc sulfate | 3 | 3 | 1 | 1 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 2 |
- na - data not available
• Control Valve Sizing
• Corrosion
• Design Strategies for Piping Systems
Piping systems design strategies - documentation, P&ID, flow diagrams - capacities and limits.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Machinability
The machinability of some common metals.
Metals - Specific Heats
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
Polyurethane - Chemical Resistance
Chemical resistance of Polyurethane (PUR).
Potassium - Thermophysical Properties vs. Temperature
Thermophysical properties of potassium.
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
Sulfuric Acid - Density
Density of sulfuric acid at various temperatures and concentrations.
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic types of corrosion.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
