Steel Pipes - Corrosion due to Oxygen
Corrosion of steel is strongly affected by the amount of oxygen in the water and the temperature of the water. The effects of oxygen and temperature on low-carbon steel pipes with water flow are indicated in the diagrams below:
- 1 mm = 0.03937 in
- T(oF) = (T(oC))(9/5) + 32
- 1 ppm = 1 mg/liter
The diagrams indicates clearly how important it is to avoid continuously fresh water supply in higher temperature systems - like heating systems or similar - where the piping is made of carbon steel.
• Corrosion
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Parts per Million - ppm
ppm - or parts per million - is commonly used as a unit of concentration.
Pipes - Corrosion Protection
A corrosion protection tutorial for piping systems.
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic types of corrosion.
