Metals in Seawater - Galvanic Series
Galvanic series in seawater at 25 oC (77 oF) are indicated below with the most noble at top.
  • Platinum
  • Gold
  • Graphite
  • Titanium
  • Silver
  • Chlorimet 3 (62 Ni + 18 Cr + 18 Mo)
  • HASTELLOY®; alloy C (62Ni + 17 Cr + 15 Mo)
  • INCONEL® alloy 625
  • INCONEL® alloy 825
  • Stainless steel, type 316 (passive)
  • Stainless steel, type 304 (passive)
  • Stainless steel, type 410 (passive)
  • Monel alloy 400
  • INCONEL® alloy 600 (passive)
  • Nickel 200 (passive)
  • Copper alloy C71500 (Cu 30% Ni)
  • Copper alloy C23000 (red brass 85% Cu)
  • Copper alloy C27000 (yellow brass 65% Cu)
  • HASTELLOY® alloy B
  • INCONEL® alloy 600 (active)
  • Nickel 200 (active)
  • Copper alloy C46400
  • Copper alloy C46500
  • Copper alloy C46600
  • Copper alloy C46700 (naval brass)
  • Tin
  • Lead
  • Lead-Tin solders
  • Hastelloy A
  • Stainless steel, type 316 (active)
  • Stainless steel, type 304 (active)
  • 50 - 50 lead tin solder
  • Stainless steel, type 410 (active)
  • Cast iron
  • Wrought iron
  • Low carbon steel
  • Aluminum alloy 2117
  • Aluminum alloy 2017
  • Aluminum alloy 2024
  • Cadmium
  • Aluminum alloy 5052
  • Aluminum alloy 3004
  • Aluminum alloy 3003
  • Aluminum alloy 1100
  • Aluminum alloy 6053
  • Galvanized steel
  • Zinc
  • Magnesium alloys
  • Magnesium
Corrosion
Material Properties
Glossary of Corrosion Related Terms
Commonly used terms related corrosion.
Pipes - Corrosion Protection
A corrosion protection tutorial for piping systems.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Salinity of Water
Salinity - salt content - of fresh, brackish and sea water.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic types of corrosion.
