Salinity of Water
Salinity is the saltiness or measure of dissolved salt in water.
- 35 g dissolved salt / kg sea water = 35 ppt = 35 o/oo = 3.5% = 35000 ppm = 35000 mg/l
Saline in Water
- fresh water (typical city water in United States) : < 100 ppm
- water supply typicaly restricted to : 500 ppm
- fresh water - official salt concentration limits in drinking water US: 1000 ppm
- typical limit agriculture irrigation : 2000 ppm
- brackish water, mildly : 1000 - 5,000 ppm
- brackish water, moderately : 5000 - 15000 ppm
- brackish water, heavily : 15000 - 35000 ppm
- seawater : 30000 - 50000 ppm (approx. 35000)
- brine > 50000 ppm
- Dead sea : 330000 ppm
Dissolved Salts in Sea Water
Typical salts dissolved in sea water;
| Component | Mass (gram/kgwater) - t - (oC) |
| Pure water | 965.31 |
| Chlorine | 19.10 |
| Sodium | 10.62 |
| Magnesium | 1.28 |
| Sulfur | 2.66 |
| Calcium | 0.40 |
| Potassium | 0.38 |
| Minor constituents | 0.24 |
| Trace constituents | 0.01 |
| SUM | 1000.00 |
• Environment
Ionic Compounds in Water - Solubility Guidelines
Guidelines or solubility rules to predict whether or not a given ionic compound is soluble in water at room temperature.
Liquid Densities
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
Salinity of Water
Salinity - salt content - of fresh, brackish and sea water.
Salinity of Water
Seawater - Attenuation of Sound
Attenuation of sound in seawater vs. temperature and frequency.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Soft or Hard Water
Carbonates dissolved in water.
Solubility Product Constants
The equilibrium constant, Ksp, for aqueous solutions of ionic compounds at 25°C.
Sugar Solubility in Water
Solubility of sugar in water.
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
