Normally dissolved oxygen from air in fresh water and sea water (salt water) at pressures ranging 1 - 4 bar abs are indicated in the diagrams and tables below.
Note! - in air with normal composition the oxygen partial pressure is 20% of the total pressure. This results in 20% oxygen dissolution from air compared to pure oxygen.
The salinity of seawater in oceans ranges 30 to 50 parts per thousand (30,000 - 50,000 ppm), on average 35 ppt.
- 35 g dissolved salt / kg sea water = 35 ppt = 35 o/oo = 3.5% = 35,000 ppm
The salinity is not uniform and vary with location and depth. Water with salinity between freshwater and seawater is called brackish.
Oxygen Solubility in Fresh Water - Salinity ~ 0
| Salinity ~ 0 | ||||||||||
| Pressure abs | mm Hg | 760 | 1520 | 3040 | ||||||
| psi | 14.7 | 29.3 | 58.7 | |||||||
| bar | 1 | 2 | 4 | |||||||
| kPa | 101.1 | 202.2 | 404.3 | |||||||
| Temperature | Solubility | |||||||||
| oC | oF | μMol | mg/l | ml/l | μMol | mg/l | ml/l | μMol | mg/l | ml/l |
| 0 | 32 | 457 | 14.6 | 10.2 | 913 | 29.2 | 20.5 | 1823 | 58.4 | 40.9 |
| 5 | 41 | 399 | 12.8 | 9.1 | 798 | 25.5 | 18.2 | 1595 | 51.1 | 36.4 |
| 10 | 50 | 353 | 11.3 | 8.2 | 705 | 22.6 | 16.4 | 1411 | 45.1 | 32.8 |
| 15 | 59 | 315 | 10.1 | 7.5 | 630 | 20.2 | 14.9 | 1260 | 40.3 | 29.8 |
| 20 | 68 | 284 | 9.1 | 6.8 | 568 | 18.2 | 13.7 | 1137 | 36.4 | 27.3 |
| 25 | 77 | 258 | 8.3 | 6.3 | 517 | 16.5 | 12.6 | 1034 | 33.1 | 25.3 |
| 30 | 86 | 236 | 7.6 | 5.9 | 473 | 15.2 | 11.8 | 947 | 30.3 | 23.6 |
| 35 | 95 | 218 | 7 | 5.5 | 436 | 14 | 11 | 872 | 27.9 | 22.1 |
| 40 | 104 | 202 | 6.5 | 5.2 | 404 | 12.9 | 10.4 | 808 | 25.9 | 20.8 |
| 45 | 113 | 189 | 6 | 4.9 | 375 | 12 | 9.8 | 751 | 24 | 16.9 |
| 50 | 122 | 177 | 5.6 | 4.6 | 355 | 11.3 | 9.3 | 710 | 22.7 | 18.7 |
Oxygen Solubility in Seawater - Salinity ~ 35
| Salinity ~35 | ||||||||||
| 0 | 32 | 349 | 11.2 | 7.8 | 699 | 22.4 | 15.7 | 1399 | 44.8 | 31.3 |
| 5 | 41 | 308 | 9.9 | 7 | 616 | 19.7 | 14.1 | 1233 | 39 | 28 |
| 10 | 50 | 275 | 8.8 | 6.4 | 550 | 17.6 | 12.8 | 1099 | 35.2 | 25.6 |
| 15 | 59 | 248 | 7.9 | 5.9 | 495 | 15.9 | 11.7 | 991 | 31.7 | 23.4 |
| 20 | 68 | 225 | 7.2 | 5.4 | 450 | 14.4 | 10.8 | 901 | 28.8 | 21.7 |
| 25 | 77 | 206 | 6.6 | 5 | 413 | 13.2 | 10.1 | 826 | 26.4 | 20.2 |
| 30 | 86 | 190 | 6.1 | 4.7 | 381 | 12.2 | 9.5 | 761 | 24.4 | 18.9 |
| 35 | 95 | 176 | 5.6 | 4.5 | 353 | 11.3 | 8.9 | 706 | 22.6 | 17.9 |
| 40 | 104 | 165 | 5.3 | 4.2 | 329 | 10.5 | 8.5 | 658 | 21.1 | 16.9 |
| 45 | 113 | 154 | 4.9 | 4 | 308 | 9.9 | 8 | 616 | 19.7 | 16.1 |
| 50 | 122 | 146 | 4.6 | 3.8 | 292 | 9.4 | 7.7 | 585 | 18.7 | 15.4 |
- dissolution of pure oxygen
Specific heat of Oxygen Gas - O2 - at temperatures ranging 175 - 6000 K.
Salinity of Water
Salinity - salt content - of fresh, brackish and sea water.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Soft or Hard Water
Carbonates dissolved in water.
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
