- T -
(K)
The values above apply to undissociated states. At high temperatures above 1500 K dissociation becomes appreciable and pressure is a significant variable.
See also other properties of Oxygen at varying temperature and pressure: Density and specific weight and Dynamic and Kinematic Viscosity , and Thermophysical properties at standard conditions ,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Hydrogen , Methane , Methanol , Nitrogen , Propane and Water .
Solubility of oxygen in equilibration with air in fresh water and seawater (salt water) - pressures ranging 1 - 4 bar abs.
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
