Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
The specific heat - C P and C V - will vary with temperature. When calculating mass and volume flow of a substance in heated or cooled systems with high accuracy - the specific heat should be corrected according values in the table below.
Specific heat of Carbon Dioxide gas - CO 2 - at temperatures ranging 175 - 6000 K :
Temperature - T - (K) | Specific Heat - c p - (kJ/(kg K)) |
175 | 0.709 |
200 | 0.735 |
225 | 0.763 |
250 | 0.791 |
275 | 0.819 |
300 | 0.846 |
325 | 0.871 |
350 | 0.895 |
375 | 0.918 |
400 | 0.939 |
450 | 0.978 |
500 | 1.014 |
550 | 1.046 |
600 | 1.075 |
650 | 1.102 |
700 | 1.126 |
750 | 1.148 |
800 | 1.168 |
850 | 1.187 |
900 | 1.204 |
950 | 1.220 |
1000 | 1.234 |
1050 | 1.247 |
1100 | 1.259 |
1150 | 1.270 |
1200 | 1.280 |
1250 | 1.290 |
1300 | 1.298 |
1350 | 1.306 |
1400 | 1.313 |
1500 | 1.326 |
1600 | 1.338 |
1700 | 1.348 |
1800 | 1.356 |
1900 | 1.364 |
2000 | 1.371 |
2100 | 1.377 |
2200 | 1.383 |
2300 | 1.388 |
2400 | 1.393 |
2500 | 1.397 |
2600 | 1.401 |
2700 | 1.404 |
2800 | 1.408 |
2900 | 1.411 |
3000 | 1.414 |
3500 | 1.427 |
4000 | 1.437 |
4500 | 1.446 |
5000 | 1.455 |
5500 | 1.465 |
6000 | 1.476 |
The values above apply to undissociated states. At high temperatures above 1500 K (3223 o F) dissociation becomes appreciable and pressure is a significant variable.
See also other properties of Carbon Dioxide at varying temperature and pressure: Density and specific weight , Dynamic and kinematic viscosity , Prandtl number , Thermal conductivity , and Thermophysical properties at standard conditions , as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon monoxide , Ethane , Ethanol , Ethylene , Hydrogen , Methane , Methanol , Nitrogen , Oxygen , Propane and Water .
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
CO2 acceptance and comfort level.
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide emission from persons vs. activity.
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
