CO2 Calculator - Emissions from Trains
Online CO2calculator for travel by train
By filling in the required information, the calculator below can be used to estimate the CO2emissions from your travels by train.
Additionally, it compares with emissions from alternative ways of travel.
How far do you travel?
Kilometer Miles
How is the utilization of train capasity?
% filled up (for trains, typical average filling degree is between 30 and 55%)
Choose the actual energy source of your train (definitions are given below) :
Diesel Low CO2el Medium CO2el High CO2el
Not sure how far you are going?   See Driving distance between European cities and Flight distances between cities in and between different continents.
See also similar CO2calculators for more details about emissions from cars and airplanes .
Unit converter for conversion to and from non-SI units.
A few words about the assumptions for the calculator:
  • The CO2emissions are strongly dependent on the energy source of the trains. We have used four different classes:
    Diesel:               No electric power
    Low CO2el:       Mainly non-emission electric power (hydroelectric, sun, wind etc)
    Medium CO2el: An even blend of non-emission electric power and power from power plants fired with hydrocarbons (gass, oil or coal)
    High CO2el:      Mainly power from hydrocarbon fired power plants
  • In comparison with alternative ways of travel, the efficiency regard to distance is set to be:
    Train:  1 (reference)
    Bus:   0.95 km/km train
    Car:    0.92 km/km train
    Plane: 0.75 km/km train
    (The difference is due to more straight driving lines for cars and planes)
  • Electrical cars are assumed to have the same electricity source as the trains on electrical power. Diesel trains are compared with electrical cars using Medium CO2el.
Miscellaneous
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Distance between Cities
Flight distances between selected cities in different countries and continents, to be used to calculate CO2 emissions from long distance flights.
Driving Distances between European Cities
Driving distance between some major European cities.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
