ρ = m / V (1)
γ = (m g) / V
= ρ g (2)
Tabulated values of carbon dioxide density at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Carbon Dioxide Density Calculator
The calculator below can be used to estimate the density and specific weight of gaseous carbon dioxide at given temperature and pressure.
Choose the actual pressure:
See also other properties of Carbon dioxide at varying temperature and pressure: Dynamic and kinematic viscosity, Prandtl number, Specific heat (Heat capacity) and Thermal conductivity, and Thermophysical properties at standard conditions, as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Density and specific weight of carbon dioxide at given temperatures and pressures:
State | Temperature | Pressure | Density | Specific weight | ||||||||
(K) | (°C) | (°F) | (MPa) | (bara) | (psia) | (mol/dm3) | (g/l) (kg/m3) | (lbm/ft3) | (sl/ft3 ×10-3) | (N/m3) | (lbf/ft3) | |
Gas | 220 | -53.2 | -63.7 | 0.1 | 1 | 14.5 | 0.05542 | 2.439 | 0.1523 | 4.732 | 23.9 | 0.152 |
240 | -33.2 | -27.7 | 0.1 | 1 | 14.5 | 0.05063 | 2.228 | 0.1391 | 4.323 | 21.8 | 0.139 | |
250 | -23.2 | -9.7 | 0.1 | 1 | 14.5 | 0.04854 | 2.136 | 0.1334 | 4.145 | 21.0 | 0.133 | |
260 | -13.2 | 8.3 | 0.1 | 1 | 14.5 | 0.04663 | 2.052 | 0.1281 | 3.982 | 20.1 | 0.128 | |
280 | 6.9 | 44.3 | 0.1 | 1 | 14.5 | 0.04322 | 1.902 | 0.1187 | 3.690 | 18.7 | 0.119 | |
300 | 26.9 | 80.3 | 0.1 | 1 | 14.5 | 0.04029 | 1.773 | 0.1107 | 3.440 | 17.4 | 0.111 | |
320 | 47 | 116 | 0.1 | 1 | 14.5 | 0.03774 | 1.661 | 0.1037 | 3.223 | 16.3 | 0.104 | |
340 | 67 | 152 | 0.1 | 1 | 14.5 | 0.03549 | 1.562 | 0.09751 | 3.031 | 15.3 | 0.0975 | |
360 | 87 | 188 | 0.1 | 1 | 14.5 | 0.03349 | 1.474 | 0.09202 | 2.860 | 14.5 | 0.0920 | |
400 | 127 | 260 | 0.1 | 1 | 14.5 | 0.03013 | 1.326 | 0.08278 | 2.573 | 13.0 | 0.0828 | |
450 | 177 | 350 | 0.1 | 1 | 14.5 | 0.02658 | 1.170 | 0.07303 | 2.270 | 11.5 | 0.0730 | |
500 | 227 | 440 | 0.1 | 1 | 14.5 | 0.02406 | 1.059 | 0.06611 | 2.055 | 10.4 | 0.0661 | |
600 | 327 | 620 | 0.1 | 1 | 14.5 | 0.02005 | 0.8824 | 0.05509 | 1.712 | 8.65 | 0.0551 | |
650 | 377 | 710 | 0.1 | 1 | 14.5 | 0.01851 | 0.8144 | 0.05084 | 1.580 | 7.99 | 0.0508 | |
850 | 577 | 1070 | 0.1 | 1 | 14.5 | 0.01415 | 0.6226 | 0.03887 | 1.208 | 6.11 | 0.0389 | |
1050 | 777 | 1430 | 0.1 | 1 | 14.5 | 0.01145 | 0.5040 | 0.03146 | 0.978 | 4.94 | 0.0315 | |
Gas | 233.03 | -40.1 | -40.2 | 1 | 10 | 145 | 0.5910 | 26.01 | 1.624 | 50.47 | 255 | 1.62 |
240 | -33.2 | -27.7 | 1 | 10 | 145 | 0.5649 | 24.86 | 1.552 | 48.24 | 244 | 1.55 | |
250 | -23.2 | -9.7 | 1 | 10 | 145 | 0.5325 | 23.44 | 1.463 | 45.47 | 230 | 1.46 | |
260 | -13.2 | 8.3 | 1 | 10 | 145 | 0.5047 | 22.21 | 1.387 | 43.09 | 218 | 1.39 | |
280 | 6.9 | 44.3 | 1 | 10 | 145 | 0.4590 | 20.20 | 1.261 | 39.19 | 198 | 1.26 | |
300 | 26.9 | 80.3 | 1 | 10 | 145 | 0.4222 | 18.58 | 1.160 | 36.05 | 182 | 1.16 | |
320 | 47 | 116 | 1 | 10 | 145 | 0.3915 | 17.23 | 1.076 | 33.43 | 169 | 1.08 | |
340 | 67 | 152 | 1 | 10 | 145 | 0.3656 | 16.09 | 1.004 | 31.22 | 158 | 1.00 | |
360 | 87 | 188 | 1 | 10 | 145 | 0.3433 | 15.11 | 0.9433 | 29.32 | 148 | 0.943 | |
400 | 127 | 260 | 1 | 10 | 145 | 0.3063 | 13.48 | 0.8415 | 26.16 | 132 | 0.842 | |
450 | 177 | 350 | 1 | 10 | 145 | 0.2704 | 11.90 | 0.7428 | 23.09 | 117 | 0.743 | |
500 | 227 | 440 | 1 | 10 | 145 | 0.2422 | 10.66 | 0.6655 | 20.68 | 105 | 0.665 | |
600 | 327 | 620 | 1 | 10 | 145 | 0.2010 | 8.845 | 0.5522 | 17.16 | 86.7 | 0.552 | |
650 | 377 | 710 | 1 | 10 | 145 | 0.1853 | 8.154 | 0.5090 | 15.82 | 80.0 | 0.509 | |
850 | 577 | 1070 | 1 | 10 | 145 | 0.1413 | 6.219 | 0.3882 | 12.07 | 61.0 | 0.388 | |
1050 | 777 | 1430 | 1 | 10 | 145 | 0.1143 | 5.030 | 0.3140 | 9.760 | 49.3 | 0.314 | |
Liquid | 250 | -23.2 | -9.7 | 5 | 50 | 725 | 24.06 | 1059 | 66.10 | 2055 | 10384 | 66.1 |
287.43 | 14.3 | 57.7 | 5 | 50 | 725 | 18.80 | 827.3 | 51.65 | 1605 | 8113 | 51.6 | |
Gas | 287.43 | 14.3 | 57.7 | 5 | 50 | 725 | 3.560 | 156.67 | 9.781 | 304.0 | 1536 | 9.78 |
450 | 177 | 350 | 5 | 50 | 725 | 1.416 | 62.30 | 3.889 | 120.9 | 611 | 3.89 | |
650 | 377 | 710 | 5 | 50 | 725 | 0.9298 | 40.92 | 2.555 | 79.40 | 401 | 2.55 | |
850 | 577 | 1070 | 5 | 50 | 725 | 0.7024 | 30.91 | 1.930 | 59.98 | 303 | 1.93 | |
1050 | 777 | 1430 | 5 | 50 | 725 | 0.5666 | 24.93 | 1.557 | 48.38 | 245 | 1.56 | |
Liquid | 250 | -23.2 | -9.7 | 10 | 100 | 1450 | 24.46 | 1076 | 67.20 | 2089 | 10556 | 67.2 |
Supercritical phase | 450 | 177 | 350 | 10 | 100 | 1450 | 2.991 | 131.6 | 8.218 | 255.4 | 1291 | 8.22 |
650 | 377 | 710 | 10 | 100 | 1450 | 1.863 | 82.00 | 5.119 | 159.1 | 804.1 | 5.12 | |
850 | 577 | 1070 | 10 | 100 | 1450 | 1.393 | 61.31 | 3.827 | 119.0 | 601 | 3.83 | |
1050 | 777 | 1430 | 10 | 100 | 1450 | 1.121 | 49.31 | 3.078 | 95.68 | 484 | 3.08 | |
Supercritical phase | 250 | -23.2 | -9.7 | 100 | 1000 | 14504 | 28.08 | 1236 | 77.13 | 2397 | 12117 | 77.1 |
450 | 177 | 350 | 100 | 1000 | 14504 | 19.25 | 847.0 | 52.88 | 1643 | 8306 | 52.9 | |
650 | 377 | 710 | 100 | 1000 | 14504 | 13.68 | 601.9 | 37.58 | 1168 | 5903 | 37.6 | |
850 | 577 | 1070 | 100 | 1000 | 14504 | 10.64 | 468.1 | 29.22 | 908.2 | 4590 | 29.2 | |
1050 | 777 | 1430 | 100 | 1000 | 14504 | 8.793 | 387.0 | 24.16 | 750.8 | 3795 | 24.2 |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - CO2 - Liquid - Properties, Imperial Units
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Carbon Dioxide - Liquid Properties
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Dioxide Emission from the Human Body vs. Activity
Carbon Dioxide emission from persons vs. activity.
Carbon Dioxide Gas - Ideal Properties
Enthalpy, Entropy and Internal Energy of Carbon Dioxide gas.
CO2 Calculator - Emissions from Trains
Calculator for CO2 emissions from trains, comparing with alternative forms of transportation (as plane, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Airplanes
Calculator for CO2 emissions from planes, comparing with alternative forms of transportation (as train, bus, conventional and electrical cars).
CO2 Calculator - Emissions from Cars
Calculator for CO2 emissions from different kind of cars (gasoline, diesel, LPG, electrical), comparing with alternative forms of transportation (as airplane, bus and train).
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Concentration of Carbon Dioxide in the Atmosphere
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Water Density, Specific Weight & Thermal Expansion Coefficients
Explore the density, specific weight & thermal expansion coefficients of water at different temperatures. This page provides a comprehensive reference table and essential calculations for engineers and scientists.
