*) normal carbon dioxide concentration in outside air is aprox. 400 ppm (0.0004 m3/m3).
With an approximately carbon dioxide emission per person in a cinema of 0.05 m3/h - the CO2 emission from 100 persons can be calculated to approximately 5 m3/h.
If the carbon dioxide concentration when people enters the room - and in the inlet air - is close to zero, the CO2 pollution concentration in a 500 m3 cinema after one hour and with one air shift per hour, can be calculated as:
c =( (5 m3/h) / (1 h-1) (500 m3) ) [1 - (1 / e((1 1/h) (1 h))] + ((0 m3/m3) - (0.0004 m3/m3)) (1 / e(1 1/h)(1 h)) + (0.0004 m3/m3)
= 0.0067 m3/m3 (6700 ppm)
Note! - that with 6700 ppm(0.0067 m3/m3) of CO2 in the air - adverse health effects may be expected. One air shift per hour as used in this example is not enough.
Human physiology, air quality and comfort temperatures, activity and metabolic rates, health effects of carbon monoxide and more.
Exposure limits for various air contaminants.
Ammonia and health symptoms - smell and threat to life.
Properties of saturated liquid Carbon Dioxide - CO2 - density, specific heat, kinematic viscosity, thermal conductivity and Prandtl number.
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
CO2 acceptance and comfort level.
Carbon Dioxide emission from persons vs. activity.
Exposure to Carbon Monoxide - CO and health effects.
Clo is used as a measure of clothes thermal insulation.
The atmospheric Carbon Dioxide concentration year 1959 - 2015.
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Concentration of a pollution in a limited space as a room depends on the amount of polluted material spread in the room, supply of fresh air, outlets positions and construction, principles used for supply and outlet from the space.
