Ammonia - NH3 - is a gas commonly used as a refrigerant in cooling systems.
The gas is colorless with very sharp odor. In small concentrations the gas is detectable by smell. In high concentrations the gas is an immediate hazard to life.
Concentration in Air (ppm) | Health Symptoms |
< 25 | Detectable by smell. Maximum Permissible Exposure Limit (PEL)1) |
30 | Uncomfortable, breathing support required. Maximum exposure 15 minutes1) |
50 | OSHA2) maximum exposure limit |
100 | Irritated eyes, throat and mucous membranes. Mild eye, nose, and throat irritation, may develop tolerance in 1-2 weeks with no adverse effects. |
140 | Moderate eye irritation, no long-term effect in exposures of less than 2 hours |
400 | Moderate throat irritation. Damage of mucous membranes with more than one hour exposure |
500 | Immediate danger to life limit (IDLH) |
1000 | Caustic to airway |
1700 | Fatal after short exposures - less than half an hour |
5000 | Immediate hazard to life |
> 15000 | Full body protection required |
160000 - 170000 | Flammable in air at 50oC |
- 1) ACGIH - American Conference of Industrial Hygienists
- 2) OSHA - Occupational Safety and Health Administration
Lower Flammable Limit (LFL) of Ammonia in air is 15-16% by volume.
• Air Conditioning Systems
• Physiology
Air Contaminants - Exposure Limits
Exposure limits for various air contaminants.
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Dioxide Concentration in Rooms Occupied with People
Carbon dioxide concentration in a room may indicate air quality and ventilation system efficiency.
Carbon Monoxide and Health Effects
Exposure to Carbon Monoxide - CO and health effects.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Gases - Dangerous Concentration Levels
Dangerous vs. tolerable concentration levels for some industrial gases.
Human Life Expectancy
Age and life expectancy for men and women.
Human Need of Air
Fresh air is required for respiration and for transport of heat and vapor emitted from the human body.
Parts per Million - ppm
ppm - or parts per million - is commonly used as a unit of concentration.
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
