Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) has developed a system for indicating the health, flammability, reactivity and special hazards for many common chemicals through use of the NFPA 704 Diamond.
RATINGS | HEALTH | FLAMMABILITY | REACTIVITY | SPECIAL |
4 SEVERE |
Deadly, even the slightest exposure to this substance would be life threatening. | Flash Point Below 73 F This substance is extremely flammable, volatile and explosive. |
May Detonate Substances may explode at normal temperatures and pressures. |
SPECIFIC HAZARD Radiation Acid alkali corrosive oxidizer use no water |
3 SERIOUS |
Extreme Danger: serious injury would result from exposure to this substance. | Flash Point Below 100 F Flammable, volatile or explosive at normal temperatures and pressure. |
Explosive Capable of detonation or explosion by heat, shock or water. |
2 MODERATE |
Dangerous: exposure to this substance would be hazardous to health. | Flash Point Below 200 F Moderately heated conditions may ignite this substance. |
Unstable Violent chemicals changes are possible at normal temperatures or pressures or when mixed with water. |
1 SLIGHT |
Irritation or minor injury would result from exposure to this substance. | Flash Point Above 200 Substance must be preheated to ignite. |
Normally Stable Substances which may become unstable at elevated temperatures or pressures or with water. |
O MINIMAL |
No significant hazard or health risk. | Will Not Burn. | Stable Substances remain stable with heat, pressure and with water. |
• Process Control Systems
Instrumentation, design and documentation of process control systems.
• Risk, Reliability and Safety
Ammonia and health symptoms - smell and threat to life.
Carbon Dioxide Concentration - Comfort Levels
CO2 acceptance and comfort level.
Carbon Monoxide and Health Effects
Exposure to Carbon Monoxide - CO and health effects.
Chemicals - Formulas and Trading Names
Formulas and trading names for some common chemicals.
Electrical Enclosure Types by NEMA
Description of NEMA electrical enclosures types.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Hazardous Areas - European Classification Standard
European hazardous area classification with zones, protection types, temperature codes and codes.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Hazardous Areas - Protection Techniques according European IECEx
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Hazardous Areas Protection Techniques for North America
Dust-ignition proof, explosion proof, instrinsically safe and nonincendive protection of hazardous areas.
Human Life Expectancy
Age and life expectancy for men and women.
Particle Sizes
The size of dust particles, pollen, bacteria, virus and many more.
Water Sprinkler Protected Areas and Hazard Classification
Maximum fire sprinkler protected area vs. classification and construction.
