Hazard vs. Flash Points
The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
Materials with higher flash points are less flammable or hazardous than chemicals with lower flash points.
| Hazard | Flash Point |
| Very Low Hazard | > 200 oF (93 oC) |
| Moderate Low Hazard | 150 oF to 200 oF (66 oC to 93 oC) |
| High to Moderate Hazard | 100 oF to 150 oF (38 oC to 66 oC) |
| Extreme to High Hazard | 0 oF to 100 oF (-18 oC to 38 oC) |
| Extreme Hazard | < 0 oF (-18 oC) |
An open flame is not always necessary to ignite a gas. A hot surface - like a heating element or warm machine - will do for chemicals with more than high hazard.
See Autoignition temperature and flash point of different hydrocarbons and Flash Point - Fuels for measured values of flash point.
The Flash Point is not the same as the Auto-Ignition Temperature. The Auto-Ignition Temperature is the minimum temperature required to ignite a gas or vapor in air without a spark or flame present.
• Risk, Reliability and Safety
Chemicals - Formulas and Trading Names
Formulas and trading names for some common chemicals.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Flash Points - Liquids
The flash points for some common liquids and fuels.
Flash Steam Generation - SI-units
When condensate leaves the steam traps - flash steam is generated. Amount of flash steam generated at different pressures - kN/m2.
Gases - Dangerous Concentration Levels
Dangerous vs. tolerable concentration levels for some industrial gases.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Hazardous Areas - Protection Techniques according European IECEx
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Hazardous Areas Protection Techniques for North America
Dust-ignition proof, explosion proof, instrinsically safe and nonincendive protection of hazardous areas.
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Steam Flash Generation (bar)
The amount of flash steam generated depends on steam pressure and pressure in the condensate lines.
Water Sprinkler Protected Areas and Hazard Classification
Maximum fire sprinkler protected area vs. classification and construction.
