Flash Steam Generation - SI-units
The amount of flash steam generated depend on the steam pressure - the pressure in the condensate before it leaves the condensate trap - and the condensate pressure after the trap - the pressure in the condensate return pipe lines.
The table below indicates the ratio of flash steam generated at different pressures before and after the condensate trap.
Absolute Pressure before the condensate trap (kN/m2) | Temperature (oC) | Percent Flash Steam of Condensate (%) | |||||
Absolute Pressure after the condensate trap (kN/m2) | |||||||
400 | 260 | 170 | 101.33 | 65 | 35 | ||
1500 | 198.3 | 11.3 | 14.0 | 16.4 | 18.9 | 20.4 | 23.2 |
1150 | 186.0 | 8.7 | 11.5 | 13.9 | 16.5 | 18.4 | 20.9 |
800 | 170.4 | 5.5 | 8.2 | 10.8 | 13.4 | 15.4 | 17.9 |
650 | 162.4 | 3.7 | 6.5 | 9.1 | 11.8 | 13.7 | 16.3 |
500 | 151.8 | 1.6 | 4.6 | 7.1 | 9.8 | 11.8 | 14.4 |
400 | 143.6 | 3.0 | 5.5 | 8.3 | 10.3 | 12.9 | |
260 | 128.7 | 2.6 | 5.4 | 7.5 | 10.2 | ||
170 | 115.2 | 2.8 | 5.0 | 7.7 | |||
101.33 | 100 | 2.2 | 4.9 |
Example - Generated Flash Steam
A condensate system is vented to the surroundings and the pressure in the condensate system after the condensate traps is 101.33 kN/m2. The absolute steam pressure before the condensate trap is 1150 kN/m2.
According the table above 16.5% of the condensate will evaporate as flash steam after the trap.
Note! Without any flash recovery system the energy in the flash steam will be lost to the surroundings.
• Flash Steam
Generation of flash steam in steam and condensate systems. Thermodynamic fundamentals, heat loss, energy recovery and more.
• Steam and Condensate
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Flash Steam Energy Loss
When flash steam is generated and vented to the surroundings a considerable amount of energy is lost
Flash Steam Generation - Fundamental Physics
Tutorial to the basic physics behind flash steam generation
Flash Steam Generation - Imperial Units (psig)
When condensate passes steam traps - flash steam is generated.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Steam Flash Generation (bar)
The amount of flash steam generated depends on steam pressure and pressure in the condensate lines.
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Steam Traps - Back Pressure and Capacity
A back pressure in a condensate systems will reduce steam trap capacity
Vapor and Steam
An introduction to vapor and steam.
