Steam Traps - Back Pressure and Capacity
Steam trap capacities are reduced if there is a back pressure in the condensate system. A back pressure can be the result of excessive flash steam generation.
Back pressure and reduction in steam trap capacities:
Reduction in Steam Trap Capacity (%)
Inlet PressureBack Pressure (%)
(psig)(bar)255075
5 0.35 6 20 38
25 1.75 3 12 30
100 6.9 0 6 25
200 13.8 0 5 23
Control Valves and Equipment
Flash Steam Generation - Imperial Units (psig)
When condensate passes steam traps - flash steam is generated.
Flash Steam Generation - SI-units
When condensate leaves the steam traps - flash steam is generated. Amount of flash steam generated at different pressures - kN/m2.
Steam Flash Generation (bar)
The amount of flash steam generated depends on steam pressure and pressure in the condensate lines.
Steam Trap Selection Guide
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
Steam Traps - Safety Factors
Selection of steam traps and their safety factors.
