Flash Steam Generation - Fundamental Physics
If the pressure of condensate - the saturated water at the boiling point at the actual pressure - is reduced, the heat energy in the water is reduced to a level appropriate to the final pressure. The relation pressure and the boiling temperature can be found in steam tables.
The energy - or enthalpy - made available when pressure is reduced, will evaporate a part of the water, producing flash steam.
Only a part of the condensate evaporates as flash steam. How much depends on the enthalpy in the condensate at the initial and the final pressures.
The amount of flash steam produced during the pressure reduction can be calculated:
w = (hil - hfl) / hfe (1)
w = ratio of flash steam generated (kg flash steam / kg condensate)
hil = initial condensate enthalpy (kJ/kg, Btu/lb)
hfl = final condensate enthalpy (kJ/kg, Btu/lb)
hfe = enthalpy of evaporation of condensate at final condition (kJ/kg, Btu/lb)
It is common that the final condition is atmospheric pressure 0 bar gauge (1 bar absolute) and temperature 100 oC. But closed condensate receivers with some pressure elevated condensate temperature are also used.
Example - Flash Steam Generation
Condensate is produced inside an heat exchanger with steam pressure 5 bar gauge (6 bar absolute) on the heating surfaces. The condensate at 5 bar gauge (6 bar absolute) contains 670.9 kJ/kg of heat energy - the enthalpy - at saturation temperature 159 oC.
The pressure in the condensate is reduced to atmospheric pressure - 0 bar gauge (1 bar absolute) when passing through the steam trap. The maximum heat energy - enthalpy - in the water (condensate) at atmospheric pressure and 100 oC is 419.0 kJ/kg.
Evaporation energy of water at the final condition at atmospheric pressure is 2257.9 kJ/kg.
The flash steam generated can then be calculated:
w = ((670.9 kJ/kg) - (419.0 kJ/kg)) / (2257.9 kJ/kg)
= 0.11 (kg flash steam / kg condensate)
= 11 %
Volume of Flash Steam
The volume of condensate as flash steam is much larger than the volume of condensate as condensate.
The specific volume of condensate - or water - at 100 oC (212 oF) is 0.00104 m3/kg (0.0167 ft3/lb). The specific volume of steam at atmospheric pressure is 1.67 m3/kg (26.8 ft3/lb).
Example - Volume of Flash Steam
By using the values from the example above we can calculate
- the volume of the condensate Vc
Vc = (1 - 0.11) (0.00104 m3/kg)
= 0.00093 m3/kg
- the volume of the flash steam Vf
Vf = 0.11 (1.67 m3/kg)
= 0.1837 m3/kg
This is a flash steam to condensate liquid rate of
(0.1837 m3/kg) / (0.00093 m3/kg)
= 198
Recovery of Flash Steam
Flash steam can be used to heat consumers with temperature demand lower than 100 oC (212 oF) - like HVAC systems, hot water service systems and similar.
• Flash Steam
Generation of flash steam in steam and condensate systems. Thermodynamic fundamentals, heat loss, energy recovery and more.
Condensate Generated in Cold Steam Pipes - Sizing of Steam Traps
When cold steam pipes are heated up they generate huge amounts of condensate that must be drained away from the pipe through steam traps - in Imperial Units.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Flash Steam Energy Loss
When flash steam is generated and vented to the surroundings a considerable amount of energy is lost
Flash Steam Generation - Imperial Units (psig)
When condensate passes steam traps - flash steam is generated.
Flash Steam Generation - SI-units
When condensate leaves the steam traps - flash steam is generated. Amount of flash steam generated at different pressures - kN/m2.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam Flash Generation (bar)
The amount of flash steam generated depends on steam pressure and pressure in the condensate lines.
Steam Traps - Safety Factors
Selection of steam traps and their safety factors.
Thermodynamic Properties of Saturated Steam: Data & Charts in Bar
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Wet Steam - Enthalpy
Wet Steam - Quality vs. Dryness Fractions
Introduction and definition of steam quality and dryness fraction including calculating wet steam enthalpy and specific volume.
