1) It is common to vent condensate systems to the atmosphere - where the gauge pressure is 0 bar.
A condensate system is vented to the surroundings and the pressure in the condensate system after the condensate traps is 0 bar gauge. The absolute steam pressure before the condensate trap is 10 bar gauge.
According the table above 16.1% of the condensate evaporates as flash steam after the trap.
Note! Without a flash recovery system the energy in the flash steam will be lost to the surroundings.
If you prefer Imperial units - go here!
Flash steam generation - thermodynamic fundamentals, heat loss, energy recovery and more.
Calculate flash steam generation in condensate pipe lines.
When flash steam is generated and vented to the surroundings a considerable amount of energy is lost
Tutorial to the basic physics behind flash steam generation
When condensate passes steam traps - flash steam is generated.
When condensate leaves the steam traps - flash steam is generated. Amount of flash steam generated at different pressures - kN/m2.
The flash point of a chemical indicates how easy it may ignite and burn.
Saturated Steam Table with properties like boiling point, specific volume, density, specific enthalpy, specific heat and latent heat of vaporization.
Steam trap selection guide - Float & Thermostatic, Inverted Bucket, Bimetal Thermostatic, Impulse and Thermodynamic Disc steam traps.
A back pressure in a condensate systems will reduce steam trap capacity
An introduction to vapor and steam.
