Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
Condensate Pipe Lines - Friction Resistance Imperial Units
Friction or major resistance in condensate pipe lines.
Condensate Pipe Lines - Sizing
Flow and pressure loss in condensate return lines - SI Units.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Feed Pumps in Steam Systems - Suction Lift Head vs. Temperature
Cavitation of impellers increases with water temperatures.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Recommended Velocities in Steam Systems
The steam velocity in a steam distribution system should be within certain limits to avoid excessive wear and tear
Sizing Steam Pipes (kg/h)
Steam is a compressible gas where pipe line mass flow capacity depends on steam pressure.
Sizing Steam Pipes (lb/h)
Steam - Condensate Pipe Lines - Capacities (kW)
Maximum capacities for condensate pipe lines in kW steam consumption.
Steam - Gravity Return Condensate Pipes - Capacities
Max. capacities (lb/hour) in gravity condensate return lines.
Calculate the stress in steam boiler shells caused by steam pressure.
Steam Flow Rate vs. Pressure Drop - Schedule 40 Pipe
Flow rate (lb/h) and pressure drop per 100 feet of pipe.
Steam Heating Systems - Classifications
Steam systems carries heat through pipes from the boiler to consumers as heat exchangers, process equipment etc.
Steam Pipes - Online Pressure drop Calculator
Calculate pressure drops in steam distribution pipe lines.
Steam Pipes - Pressure Drop vs. Steam Flow
Steam pipes and pressure drop diagrams - imperial and metric units.
Steam Pipes - Sizing
Sizing of steam pipe lines - major and minor loss in steam distribution systems.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steam Traps - Safety Factors
Selection of steam traps and their safety factors.
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
