Flow Coefficient Cv vs. Flow Factor Kv
The flow coefficient - Cv - or the flow factor - Kv - are commonly used to specify capacities of control valves.
Flow Coefficient - Cv
It is often convenient to express the capacity and flow characteristic of a control valve in terms of the
  • Flow Coefficient - Cv
The flow coefficient - Cv - is based on the imperial units system and is defined as:
The flow coefficient is commonly used in the U.S.
Flow Factor - Kv
The metric equivalent of the flow coefficient - Cv - is based on the SI-system and is called the
  • Flow Factor - Kv
The flow factor - Kv - is defined as
The flow factor is commonly used outside U.S.
Converting between Flow Coefficient Cv and Flow Factor Kv
The relationship between Cv and Kv can be expressed as:
  • Cv = 1.16 Kv                            (1)
  • Kv = 0.862 Cv                          (2)
Download and print Flow Coefficient - Cv vs. Kv chart
Control Valve Sizing
Design of Control and Safety Valves
Fluid Mechanics
Piping Systems
Process Control Systems
Instrumentation, design and documentation of process control systems.
Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Liquid, Steam and Gas - Flow Factor Kv
Calculate flow factor Kv for liquids, steam and gases - metric units.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Technical Terms in Fluid Mechanics
Some commonly used technical terms in fluid mechanics.
Water Control Valves - Flow Factor Kv Diagram
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Water Control Valves - Kv Calculation
Designing water process control valves and their Kv values.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
