Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm flanged cast iron valves of "Saunders" type:
Valve Size | Unlined | Rubber Lined | Halar/Glass Lined | Plastic Lined | |||||
DN | Inches | Cv | Kv | Cv | Kv | Cv | Kv | Cv | Kv |
15 | 6 | 5 | 6 | 5 | |||||
20 | 12 | 10 | 9 | 8 | 12 | 10 | 7 | 6 | |
25 | 1 | 18 | 15 | 14 | 12 | 18 | 16 | 11 | 10 |
32 | 1 | 28 | 24 | 22 | 19 | 28 | 24 | 17 | 14 |
40 | 1 | 43 | 37 | 35 | 30 | 45 | 39 | 31 | 27 |
50 | 2 | 80 | 69 | 64 | 55 | 88 | 76 | 59 | 51 |
65 | 2 | 127 | 109 | 102 | 88 | 132 | 114 | 83 | 72 |
80 | 3 | 185 | 159 | 148 | 128 | 186 | 160 | 148 | 128 |
100 | 4 | 315 | 272 | 252 | 217 | 336 | 290 | 270 | 233 |
125 | 5 | 420 | 362 | 363 | 313 | 440 | 379 | ||
150 | 6 | 605 | 522 | 484 | 417 | 630 | 543 | 505 | 435 |
200 | 8 | 1 300 | 1 121 | 1 309 | 1 128 | 1 320 | 1 138 | ||
225 | 9 | 1 630 | 1 405 | 1 320 | 1 138 | 1 680 | 1 448 | ||
250 | 10 | 1 980 | 1 707 | 2 000 | 1 724 | 2 100 | 1 810 | ||
300 | 12 | 2 550 | 2 198 | 2 600 | 2 241 | 2 700 | 2 328 | ||
350 | 14 | 3 700 | 3 190 | 3 750 | 3 233 | 3 880 | 3 345 |
• Control Valve Sizing
• Piping Systems
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves for Water Flow – Kv Sizing & Pressure Drop Calculations
Control valve sizing and pressure drop calculations for water flow applications. Different valve types, Kv flow coefficients, and how to select the right valves.
Diaphragm Valves - Diaphragm Materials
Common diaphragm materials and their main properties when used in diaphragm valves.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valve Selection Guide
Applications guide for selecting valves.
