Diaphragm Valves - Diaphragm Materials
Material | Size | Temperature | Applications | ||
inches | mm | oF | oC | ||
Butyl rubber | 0.6 - 14 | 15 - 350 | - 22 to 134 | - 30 to 90 | Acids and alkalies |
Nitril rubber | 0.6 - 14 | 15 - 350 | 14 to 134 | -10 to 90 | Oils, fats and fuels |
Neoprene | 0.6 - 14 | 15 - 350 | - 4 to 134 | - 20 to 90 | Oils, greases, air and radioactive fluids |
Natural/synthetic rubber | 0.6 - 14 | 15 - 350 | - 40 to 134 | - 40 to 90 | Abrasives, brewing and dilute mineral acids |
White natural rubber | 0.6 - 5 | 15 - 125 | - 31 to 134 | - 35 to 90 | Foods and pharmaceuticals |
White butyl | 0.6 - 6 | 15 - 150 | - 22 to 212 | - 30 to 100 | Natural color, food, plastics and pharmaceuticals |
Viton | 0.6 - 14 | 15 - 350 | 41 to 284 | 5 to 140 | Hydrocarbon acids, sulphture and chlorine applications |
Hypalon | 0.6 - 14 | 15 - 350 | 32 to 134 | 0 to 90 | Acid and ozone resistant |
Butyl rubber | 0.6 - 14 | 15 - 350 | - 4 to 248 | - 20 to 120 | Hot water and intermittent steam services, sugar refining |
• Piping Systems
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valve Selection Guide
Applications guide for selecting valves.
Valves - Specific Services
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
