Valves - Specific Services
ServicesMainSecondary
Gases Butterfly valves
Check valves
Diaphragm valves
Lubricated plug valves
Screw down stop valves
Pressure control valves
Pressure relief valves
Pressure reducing valves
Safety valves
Relief valves
Liquids - clear up to sludges and sewage Butterfly valves
Gate valves
Diaphragm valves
Pinch valves
Slurries and liquids with solids Butterfly valves
Pinch valves
Gate valves
Steam Butterfly valves
Gate valves
Turbine valves
Check valves
Pre superheated valves
Safety and relief valves
  • Slurry - a thin mixture of a liquid like water and finely divided substances, such as cement or clay particles
  • Sludge - a semi-solid slurry. Wastewater solids are also referred to as sludge.
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Piping Systems
Valve Standards
International standards for valves in piping systems.
ASME - Valve Standards
An overview of the American Society of Mechanical Engineers - ASME - valve standards.
ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves - Leakage Classification
Seat leakage classification through control valves.
Control Valves - Sizing and Selection
Sizing control valves to match process requirements.
Diaphragm Valves - Diaphragm Materials
Common diaphragm materials and their main properties when used in diaphragm valves.
ISO Valve Standards
An overview of ISO - International Organization for Standardization - valve standards.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valve Abbreviations
US valve abbreviations commonly used in drawings and documentation.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Valve Type Classifications
Categories of valves.
