With the flow coefficients capacities of valves at different sizes, types and manufacturers can be compared. The flow coefficients are in general determined experimentally and express the
flow capacity in imperial units - GPM (US gallons per minute) that a valve will pass for a pressure drop of 1 lb/in2 (psi)
The flow factor - Kv - is also commonly used with capacity in SI-units.
The flow coefficient - Cv - required for a specific application can be estimated by using specific formulas for the different fluids or gases. With an estimated Cv value - the correct size of control valve can be selected from the manufacturers catalogs.
Note that an oversized control valve may hurt process variability by putting too much gain in the valve leaving less flexibility for the controller. An oversized valve operates more frequently at lower openings with increased dead band as result.
Flow Coefficient - Cv - for Liquids
For liquids the flow coefficient - Cv -is expressed with water flow capacity in gallons per minute (GPM) of 60 oF with pressure drop 1 psi (lb/in2).
Flow expressed by volume
Cv = q (SG / dp)1/2 (1)
q = water flow (US gallons per minute)
SG = specific gravity (1 for water)
dp = pressure drop (psi)
or alternatively in metric units:
Cv = 11.6 q (SG / dp)1/2 (1b)
q = water flow (m3/hr)
dp = pressure drop (kPa)
Water Control Valves - flow coefficient Cv diagram
Flow expressed by weight
Cv = w / (500 (dp SG)1/2) (1c)
w = water flow (lb/hr)
dp = pressure drop (psia)
or alternatively in SI units:
Cv = 5.8 w / (500 (dp SG)1/2) (1d)
w = water flow (kg/hr)
Example - Flow Coefficient Liquid
The flow coefficient for a control valve which in full open position passes 25 gallons per minute of water with a one pound per square inch pressure drop can be calculated as:
Cv = (25 gpm) (1 / (1 psi))1/2
= 25
Flow Coefficient - Cv - for Saturated Steam
Since steam and gases are compressible fluids, the formula must be altered to accommodate changes in density.
Critical (Choked) Pressure Drop
With choked flow and critical pressure drop, the outlet pressure - po - after the control valve is aprox. 58% of the inlet pressure - pi - before the control valve. The flow coefficient at choked - or critical - flow can be expressed as:
Cv = m / (1.61 pi) (2)
m = steam flow (lb/hr)
pi = inlet steam absolute pressure (psia)
Critical (Choked) pressure drop in metric units:
kv = m / (12 pi) (2b)
m = steam flow (kg/hr)
pi = inlet steam absolute pressure (bara)
Non Critical Pressure Drop
For non critical pressure drop the outlet pressure - po - after the control valve is more than 58% of the inlet pressure - pi - before the control valve. The flow coefficient for non critical flow can be expressed as:
Cv = m / (2.1 ((pi + po) dp)1/2) (2c)
po = outlet steam absolute pressure (psia)
Flow Coefficient - Cv - Super-heated Steam
The flow coefficient for superheated steam should be multiplied with a correction factor:
Cv = Cv_saturated (1 + 0.00065 dt) (3)
dt = steam temperature above saturation temperature at the actual pressure (oF)
Example - flow coefficient super-heated steam
The flow coefficient for steam super-heated with 50 oF can be calculated as:
Cv = Cv_saturated (1 + 0.00065 (50 oF)
=1.0325 Cv_saturated
Flow Coefficient - Cv - Saturated Wet Steam
Saturated wet steam includes non evaporated water particles reducing the "steam quality" and a flow coefficient for very wet saturated steam should be multiplied with a correction factor:
Cv = Cv_saturated ζ1/2 (4)
ζ = dryness fraction
Example - Flow Coefficient Wet Saturated Steam
For steam with moisture content 5% the dryness fraction can be calculated as:
ζ = ws / (ww + ws)
= 0.95 / (0.95 + 0.05)
= 0.95
ww = mass of water
ws = mass of steam
The flow coefficient can be calculated as:
Cv = Cv_saturated (0.95)1/2
= 0.97 Cv_saturated
Flow Coefficient - Cv - Air and other Gases
Note! - there is a difference between critical and non critical pressure drops.
Critical pressure drop is approximately 47% of inlet pi absolute pressure. With critical pressure drop the outlet absolute pressure po is approximately 53% of inlet pi pressure.
Pressure Drop Larger than Critical Pressure Drop
For pressure drop larger than the critical pressure drop the flow is choked. The flow coefficient can be calculated as:
Cv = q (SG (T + 460))1/2 / (FL 834) pi (5)
q = free gas per hour, standard cubic feet per hour (Cu.ft/h)
SG = upstream specific gravity of flowing gas gas relative to air (SG = 1.0) at 14.7 psia and 60 oF
T = flowing air or gas temperature (oF)
FL = pressure recovery factor
pi = inlet gas absolute pressure (psia)
Gas Temperature (oF)
Pressure Drop Less than Critical Pressure Drop
For pressure drop less than the critical pressure drop the flow is not choked. The flow coefficient can be calculated as:
Cv = q (SG (T + 460))1/2 / (1360 (dp po)1/2) (5b)
dp = (pi - po)
po = outlet gas absolute pressure (psia)
• Control Valve Sizing
• Design of Control and Safety Valves
• Process Control Systems
Instrumentation, design and documentation of process control systems.
• Steam and Condensate
• Water Systems
API 6D Valves - Pressure Ratings vs. Temperature
Temperature and pressure ratings for valves according API 6D.
ASTM A216 Valves - Pressure Ratings vs. Temperature
Pressure and temperature ratings for cast carbon steel valves.
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Control Valves for Water Flow – Kv Sizing & Pressure Drop Calculations
Control valve sizing and pressure drop calculations for water flow applications. Different valve types, Kv flow coefficients, and how to select the right valves.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Liquids - Critical Pressure Ratios
Critical pressure ratios for water and other liquids.
Steam & Condensate Equations
Steam consumption and condensate generation when heating liquid or gas flows
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Steam Flow - Orifices
Steam flow through orifices - for steam pressures ranging 2 - 300 psi
Steam Pipes - Pressure Drop vs. Steam Flow
Steam pipes and pressure drop diagrams - imperial and metric units.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valve Selection Guide
Applications guide for selecting valves.
Valves - Specific Services
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
Water Control Valves - Flow Factor Kv Diagram
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
