Online Fluid Flow Unit Calculator
The calculator below can used to convert between common fluid flow units:
Flow Units Converting Table
The tables below can used to convert between some common used flow units:
| Convert from | multiply by | ||||
| Convert to | |||||
| US gpd | US gpm | cfm | IMP gpd | IMP gpm | |
| m3/s | 22800000 | 15852 | 2119 | 19000000 | 13200 |
| m3/min | 380000 | 264.2 | 35.32 | 316667 | 220 |
| m3/h | 6333.3 | 4.403 | 0.589 | 5277.8 | 3.67 |
| liter/sec | 22800 | 15.852 | 2.119 | 19000 | 13.20 |
| liter/min | 380 | 0.2642 | 0.0353 | 316.7 | 0.22 |
| liter/h | 6.33 | 0.0044 | 0.00059 | 5.28 | 0.0037 |
| US gpd | 1 | 0.000695 | 0.000093 | 0.833 | 0.000579 |
| US gpm | 1438.3 | 1 | 0.1337 | 1198.6 | 0.833 |
| cfm | 10760.3 | 7.48 | 1 | 8966.9 | 6.23 |
| Imp gpd | 1.2 | 0.00083 | 0.00011 | 1 | 0.00069 |
| Imp gpm | 1727.3 | 1.2 | 0.161 | 1439.4 | 1 |
| Convert from | multiply by | |||||
| Convert to | ||||||
| m3/s | m3/min | m3/h | liter/sec | liter/min | liter/h | |
| m3/s | 1 | 60 | 3600 | 1000 | 60000 | 3600000 |
| m3/min | 0.0167 | 1 | 60 | 16.67 | 1000 | 60000 |
| m3/h | 0.000278 | 0.0167 | 1 | 0.278 | 16.67 | 1000 |
| liter/sec | 0.001 | 0.06 | 3.6 | 1 | 60 | 3600 |
| liter/min | 0.0000167 | 0.001 | 0.06 | 0.0167 | 1 | 60 |
| liter/h | 2.7×10-7 | 0.000017 | 0.001 | 0.00028 | 0.0167 | 1 |
| US gpd | 4.39×10-8 | 0.0000026 | 0.000158 | 0.000044 | 0.0026 | 0.158 |
| US gpm | 0.000063 | 0.00379 | 0.227 | 0.0630 | 3.785 | 227.1 |
| cfm | 0.00047 | 0.028 | 1.699 | 0.472 | 28.32 | 1698.99 |
| Imp gpd | 5.26×10-8 | 0.0000032 | 0.000189 | 0.0000526 | 0.00316 | 0.1895 |
| Imp gpm | 0.000076 | 0.0046 | 0.272 | 0.076 | 4.55 | 272.7 |
Select the "from" unit in the left column and follow the row until the "to" unit column.
- gpm = gallons per minute, gpd = gallons per day, cfm = cubic feet per minute
Example - Convert from m3/h to Imperial gallons per minute (gpm)
Volume flow in m3/h must be multiplied with
3.67
to convert to Imp gpm.
Alternatively use the online fluid flow calculator above.
Related Mobile Apps from The EngineeringToolBox
Alternative Flow Units
1 Cubic metre/second = 22643 Barrel (oil)/h
1 Cubic metre/second = 6.29 Barrel (oil)/s
1 Cubic metre/second = 3.6×109 Cubic centimetre/hour
1 Cubic metre/second = 6×107Cubic centimetre/minute
1 Cubic metre/second = 106 Cubic centimetre/second
1 Cubic metre/second = 127133 Cubic feet/hour
1 Cubic metre/second = 2119 Cubic feet/minute
1 Cubic metre/second = 35.3 Cubic feet/second
1 Cubic metre/second = 3600 Cubic metre/hour
1 Cubic metre/second = 60 Cubic metre/minute
1 Cubic metre/second = 4709 Cubic yards/hour
1 Cubic metre/second = 78.5 Cubic yards/minute
1 Cubic metre/second = 1.31 Cubic yards/second
1 Cubic metre/second = 13198 Gallon water/minute (UK)
1 Cubic metre/second = 15850 Gallon water/minute (US)
1 Cubic metre/second = 951019 Gallons (FI)/hour (US)
1 Cubic metre/second = 15850 Gallons (FI)/minute (US)
1 Cubic metre/second = 264.2 Gallons (FI)/second (US)
1 Cubic metre/second = 19005330 Gallons/day (UK)
1 Cubic metre/second = 791889 Gallons/hour (UK)
1 Cubic metre/second = 13198 Gallons/minute (UK)
1 Cubic metre/second = 219.97 Gallons/second (UK)
1 Cubic metre/second = 3600000 Liter/hour
1 Cubic metre/second = 60000 Liter/minute
1 Cubic metre/second = 1000 Liter/second
1 Cubic metre/second = 131981 Pounds water/minute
1 Cubic metre/second = 86400 Ton of water (metric)/24hrs
cfm to m3/h Converter
Download and print cfm to m3/h Converter!
US gpm to l/s Converter
• Basics
• Pumps
California Pipe Flow Metering Method
Calculate the discharge length from the open end of a partially filled horizontal pipe.
Comparing Flowmeters
A limited comparison of flowmeter principles - regarding service, rangeability, pressure loss, typical accuracy, upstream pipe diameters, viscosity and relative costs.
Condensate Pipes - Flash Steam Generated
Calculate flash steam generation in condensate pipe lines.
Flowmeter - Accuracy
Fluid Mechanics - Imperial and SI Units vs. Dimensions
Imperial (USCS) and SI dimensions and units terminology in fluid mechanics.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Manning's Formula and Gravity Flow
Calculate cross-sectional average velocity flow in open channels.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
Unit Factor Method
Velocity Units - Online Converter
Convert between common velocity and speed units.
Velocity-Area Flowmetering
Flow rate or discharge in an open conduit, channel or river can be calculated with the velocity-area principle.
