Fluid Mechanics - Imperial and SI Units vs. Dimensions
Fluid mechanics in the
- Imperial or USCS - United States Customary Units
- International System of Units - SI system
| Terminology | Dimensions | Imperial Units (USCS) | SI-units |
| Acceleration due to gravity | L / T2 | ft/s2 | m/s2 |
| Area | L2 | ft2 | m2 |
| Chezy roughness coefficient | L1/2/ T | ft1/2/s | m1/2/s |
| Critical Depth | L | ft | m |
| Density | F T2/ L4 | lb s2/ ft4 |
N s2/m4 |
| Depth in open channel | L | ft | m |
| Diameter | L | ft | m |
| Distance from solid boundary | L | ft | m |
| Flow rate | L3/ T | ft3/s | m3/s |
| Force | F | lb | N |
| Force due to pressure | F | lb | N |
| Hazen Williams roughness coefficient | L0.37/ T | ft0.37/s | m0.37/s |
| Head loss due to friction | L | ft | m |
| Head of height | L | ft | m |
| Head of weir | L | ft | m |
| Height above datum | L | ft | m |
| Hydraulic radius | L | ft | m |
| Kinematic viscosity | L2/ T | ft2/s | m2/s |
| Length | L | ft | m |
| Manning's roughness coefficient | T / L1/3 | s/ft1/3 | s/m1/3 |
| Mass | F T2/ L | lb s2/ft | N s2/m |
| Modulus of elasticity | F / L2 | lb/in2 (psi) | Pa |
| Perimeter, Weir Height | L | ft | m |
| Pressure | F / L2 | lb/ft2 | Pa |
| Radius | L | ft | m |
| Shear stress | F / L2 | lb/ft2 | Pa |
| Size of roughness | L | ft | m |
| Specific weight | F / L3 | lb/ft3 | kg/m3 |
| Surface tension | F / L | lb/ft | kg/m |
| Time | T | s | s |
| Thickness | L | ft | m |
| Time | T | s | s |
| Total head | L | ft | m |
| Unit flow rate | L3/ T L | ft3/(s ft) | m3/(s ft) |
| Velocity | L / T | ft/s | m/s |
| Viscosity | F T / L2 | lb s/ft | Pa s |
| Weight | F | lbf | N |
- L - length
- F - force
- T - time
Chezys Conduit Flow Equation
Calculating volume flow and velcity in open conduits.
Hazen-Williams Friction Loss Coefficients: Data & Reference Guide
Hazen-Williams friction loss coefficients for commonly used piping materials.
Manning’s Roughness Coefficients for Open Channel Flow
Manning's roughness coefficients for some common materials.
SI System
An introduction to the SI metric system.
Symbols Used to Denote a Chemical Reactions and Process or Condition
Explanation of symbols used as subscripts or superscripts to tell more about the type of chemical reaction, process or condition.
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
USCS - United States Customary System Units
An overview of the United States Customary System Units - Imperial Units.
