Symbols Used to Denote a Chemical Reactions and Process or Condition
See also Thermodynamic Terms, Functions and Relations
Subscript Symbol | Process |
ads | adsorption |
at | atomization |
c | combustion reaction |
dil | dilution (of a solution) |
dpl | displacement |
f | formation reaction |
fus | melting, fusion (solid → liquid) |
imm | immersion |
mix | mixing of fluids |
r | reaction in general |
sol | solution (of solute in solvent) |
sub | sublimation (solid → gas) |
trs | transition (between two phases) |
vap | vaporization, evaporation (liquid → gas) |
Superscript Symbol | Process |
app | apparent |
≠, ‡ | activated complex, transition state |
E | excess quantity |
id | ideal |
∞ | infinite dilution |
* | pure substance |
°, θ | standard |
Examples of use could be:
ΔGr : Change in Gibbs free energy by (a given) reaction,
ΔHsol : Change in enthalpy by (a given) solution
ΔSvap : Change in entropy by (a given) evaporation
pθ : Pressure at standard state (normally 1 bar)
• Basics
The SI-system, unit converters, physical constants, drawing scales and more.
• Thermodynamics
1st Law of Thermodynamics
2nd Law of Thermodynamics
Entropy and disorder.
Apothecaries' Weight System
Apothecaries' fluid and weight system with ounces, drachms, grains, scruples and more.
British Imperial System
A principal system of units.
Decimal System Prefixes
Prefix names used for multiples and submultiples units.
Dimensionless Numbers
Physical and chemical dimensionless quantities - Reynolds number, Euler, Nusselt, and Prandtl number - and many more.
Fluid Mechanics - Imperial and SI Units vs. Dimensions
Imperial (USCS) and SI dimensions and units terminology in fluid mechanics.
Greek Alphabet
The Greek alphabet is essential expressing formulas and in technical language.
SI System
An introduction to the SI metric system.
Thermodynamic Terms - Functions and Relations
Common converting units for Acceleration, Area, Density, Energy, Energy per unit mass, Force, Heat flow rate, Heat flux, Heat generation per unit volume and many more.
USCS - United States Customary System Units
An overview of the United States Customary System Units - Imperial Units.
WABT - Weighted Average Bed Temperature
Definition and examples of calculation of weighted average bed temperature in adiabatic reactors.
